Digital panel meters
jonescg
Perth, Western Australia
I'm thinking of mounting a pair of digital panel meters on the dash of the race bike. I'm very proud of the simplicity of my bike's display, so for the road-legal version I want it to be similarly simple, but I need a couple of vital stats up front like amps and volts.
Voltage:
In my case, 700 V is fully charged and 590 V is spent. So a voltage readout is a pretty close proxy for state of charge. In order to get a 700 V readout on the screen I need my voltage divider to give a value between 0 and 7.00 V, and with a bit of luck, remove the decimal point. Can anyone point me in the right direction? It needs to be fairly compact, like 16 mm tall x 40 mm wide. There are "1000 volt DC" panel meters available from e-bay which take the voltage reading directly, but I wouldn't put that kind of potential anywhere near them...
Edit - just found this: http://www.farnell.com/datasheets/684076.pdf looks like it can be adjusted based on a 0-5 V signal, which is what I have currently on the divider :)
Amps:
I have a 500 A digital panel meter which works with a 75 mV shunt. Trouble is, it's pretty big and I only need a small readout, like 16 mm tall and 40 mm wide. Any clues where I can find one? An analogue meter would look pretty cool, and can no doubt run from the shunt directly (no additional power supply needed).
Isolation - these digital panel meters all require a 7-20 V power supply to run the LCD, but the grounds are common, so I will power both from the isolating DC/DC converter I have up front.
Speed and odometer - I'm thinking of getting a 91 mm analogue speedo from Speedhut. They work by GPS, which is cool. Nice and simple.
So, does Digikey or Farnell sell simple and compact meters?
Would one of these help?
http://www.ebay.co.uk/itm/New-100V-100A-DC-Digital-Voltmeter-Ammeter-LED-Amp-Volt-Meter-/400726943447?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item5d4d2fe6d7
It's about 600 V and 300 A too small, but yeah, I'm after a couple of small, low-profile panel meters. Analogue is cool too, as long as it can handle the bumps of the road.
Ran into this.
http://www.kdindustrial.com/views.asp?hw_id=200
You can fix the current problem with a lower-impedance shunt. I made my own shunt with a short length of 10AWG wire, calculated using the usual wire tables.
You can fix the voltage problem with a couple of resistors to do a voltage division. So that instead of going up to 100v and 100a, it would go up to 1000V and 1000A, and you'd need to remember to multiply the display by 10.
And because it's digital, you would have to worry about vibration destroying the meter.
Farnell have all sorts of meters.
I used some really small ones ages ago for a temperature sensor - they just need a power supply, and you can actually set where you want the decimal place - they have farnell pricing, but are a heap better quality than some of the chinese carp on fleabay.
I'll have a look in the paper catalogue tonight.
Thanks mate, just wondering how you got on? Ideally they would be powered by a 12 V supply, as I have a 10 W isolating DC/DC converter up the front of the bike for the Cycle Analyst.
