Hey all,
Longtime lurker , first time poster...
TLDR; Dillenger batteries are chinese imported rubbish.
Bit of background:-
Bought a Dillenger 500w 48V 13Ah rear hub kit back in late 2019, fitted to a friday bike and ridden so far about 5-600km.
With covid lockdown it didn't get much use, and unfortunately I had the battery sitting idle for like 3 months , from a fully charged state.
Went to start using the ebike again, plug charger to the battery, check the status lights on battery... not good
2 faint colour, 1 green , 1 red from left to right (the last is a red led - photo doesn't show it)
put battery into bike, panel displaying 1 battery bar, quick ride and display panel quickly showing no battery.
Put battery onto charge and left for several hours... no improvement
Decided to open it up, it's out of warranty, and Dillenger advice is buy a new battery. - no thanks.
What I found / see does not impress. WTF - Rust over several areas of nickel strip and cell tops.
ATM I'm wondering if this was just some low grade nickel strip OR
who ever put this battery together spilt/dripped acid flux on the way to soldering points, wiped it up and threw in into the case.
Also IMO, the battery internal weather proofing is lacking.
DO NOT ride these batteries in the wet and I've never ridden this bike in the wet, bike is stored under cover, and I live in a dry environment area (approx 200km from coast/sea and 600m ASL)
This 48V battery has 18650 cells made by dynabat - MX18650-26P - 2600mah , looks to be your generic kinda chinese battery
I've put the multimeter across the cells and have found 5 batteries in parallel reading 0 volt. Already extracted these out.
Now the plan ATM is a budget fix-up. Replace those 5 cells with new 2600mah cells - looks like I can get my hands Sony/Murata VTC5A conveniently, and redo any of the nickel strip areas with corrosion.
BTW the BMS is
Bit of background:-
BTW the BMS is
