This week I had time to install A Dillinger kit to my Giant 29er.
The hub when it arrived was already scratched in many places. The rim has scratch marks where the spokes have been tightened.
On the rear hub three out of the six disk brake treads were of such a depth that the supplied socked headed cap screws bottomed out before they contacted thread. They were either stripped out or they were drilled incorrectly. Socked headed bolts had to be manufactured and the holes re-tapped. surprisingly the problem holes were all on one side in a row. The other three holes were not a problem.
The computer display when removed from its box had a fog inside the display that is reminiscent of a LCD that has water inside it, There is no doubt that as it's a sealed unit it is likely to fail latter due to the water already inside it.
The rear rack is not suitable for a rear suspension bike. It is only 50mm from the tire when mounted.
If I did not know better I would suggest this kit has been returned and then repacked and re-sent.
I purchased an Australian made kit to keep jobs here. The Chinese kits I have seen are cheaper, have a better finish and better quality control. We have to do better if Australian business is to survive the cheap imports.
