Doctorbass
pgt400 said:Hey Doc,
Did you ever get a chance to compare Ypedals PSI cells to the newer Headway?
That's on the to do list!
I'm a little busy these times.
Doc
pico1 said:might as well buy a ping pack
I sent 2 of the recent PSI green sleve cells a few days ago, it would be interesting to see if they are the same as the Grey cells or not..
mcstar said:Since everyone else is showing off their flat curves....Here's what the BMI cells can do at a 10C discharge.
Notice, you get > 10AH at that discharge rate.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0271429385
auraslip said:This thread really reiterates the importance of thermal management. I was looking at the battery pack design in new hybrids, and they've put a lot of consideration into air flow!
If you want to run a headway pack above 3c, you'll need proper ventilation and temperature sensors? I have my current pack enclosed in a wooden box, but I have air vents facing the direction I travel. I thought this would be enough to scoop in all the air I needed, but I think I'm going to need to add some fans as well.
These compare favorably to ping, but it makes you wonder if ping could handle 2c with proper ventilation.
In any case a 72v10ah pack of these at 3c is 2100+watts, which is much more power than my current 48v20ah ping is capable of. When I upgrade to the aforementioned headway pack, I'm hoping I'll get at least to 40mph (up from 33mph). Ping is 1kwh, and the headway is ~750kwh. Ping cost ~$800, headway should cost ~$600-700. Ping weighs 20lb, headway will weigh 18lbs.
So they weigh and cost about the same per wh, but the headway is easier to cool, provides a higher C rate, and is easier to do maintenance on. Really the only thing ping has going for it is the reliability of the dealer, and the smaller size. Arguably the small size is a weakness because it makes it harder to cool.
