sisachosudo
- Joined
- Dec 13, 2016
- Messages
- 22
Hello guys,
After overthinking the whole issue a bit too much, I decided to start building my own project using an old bike. I am a bit lost with numbers, Amps, volts and the like so I will be updating this post with more doubts in the future.
Let me give you a picture of the initial situation:
I am looking after something to get 1000W continuous and will be limited later on if needed. After checking plenty of options, I am left with the following motors:
1.- Magic Pie V5: If I am not mistaken, the only one with built in controller.
2.- Leaf 1000W (is the 1000W direct drive?)
3.- MXUS 300X: The lightest of all the options at 6.4kg.
I would love to hear your opinions about these three motors. Do they all have torque sensor? Can they be configured to ride with PAS or throttle only?
I guess all of them have the option of reg.braking.
Thank you very much for taking the time to read this post.
- I want the motor to be a rear Direct Drive. It has to last many years and be efficient at high speeds. I plan to pedal quite a lot and I don’t mind helping after stops.
- The battery will be allocated in the downtube, using the bottle cage screws. Still to be decided but it will be in the range of 48 or 52V and 13.5 - 17Ah battery pack. Still reading about the cell types in order to make a decision.
- Motor will be mounted in a 700c sized wheel
- Very seldom I will be pulling a bike trailer (15 to 20kg) in flat terrain at low speed.
- Integrated controller and torque sensor are a big plus.
- I prefer cassette over freewheel.
