DIY LP20 Surron charging plug to xt60 adapter?
_Jo
🔌 New-ish
Australia
Chi battery makes one, LP20 3-Pin Male to XT-60 Female Adapter But im not willing to pay $30 for something i should be easily able to make my self for less than $10. I need one for my trickle charger for my surron battery, that uses xt60 instead of the surron charger plug. If i got the male surron plug and the xt60 plug, how would i wire it? because the surron plug is 3 pin, but the xt60 is 2 pin, how does Chi do it?
That is what the extra $25 is for. :D (the knowledge beyond the material costs)
What is the surron third conductor for? Is it a data pin? Does the surron charger need its data to initiate charging? Or is it a dummy pin?
idk thats what i was asking endless sphere
You can buy pigtails to make things easier. Then the adapter is just soldering or crimping the end of the wires together and heat shrinking down.
Every battery I ever took apart with 3 pin XLR was just positive, negative, and unconnected. The unconnected pin prevents you from plugging it in backwards. Always verify with a multimeter first, though.
I do buy cheap batteries, though. Theoretically there could be some signal or temperature sensor on the last pin on expensive ones. I've seen battery blenders where a third pin connects a contact to ground to enable a charging behavior vs. a discharging behavior too.
  • Like
Reactions: _Jo
