The balance wire connection between A1 and A2 is similar to charging two lipos using a paralleling board.It's an unfinished sketch, so not really, here's an updated one, still has a few things missing but I'll add things as I go
When paralleling two packs via the main discharge connectors, I look for 0.1V difference between the total pack voltages before connecting them. But, when paralleling balance connectors, as with lipo parallel charging, each cell group should also be matched before connecting, since the packs may have the same total voltages but differ at the group level if the packs aren’t balanced, similar to charging big lipos with a paralleling board.
Will A1 and A2 always remain paralleled, or will you be mixing and matching, juggling the configuration around?
