design_intent
- Joined
- May 2, 2019
- Messages
- 2
Could use some help to diagnose an issue with a custom 48V Li-ion (18650) pack - specs below.
I finished building it the other day & everything seemed fine - read 50.5V out of the BMS.
Wrapped it up and left it on the bench.
Went to test the motor and controller tonight and no voltage output from load wires!
Cut the heat shrink off to inspect. 46V total, 0V in 6th series bank (all others approx 3.8xV)
Bummer... Why?!
Any ideas what happened (these were all brand new cells and no external load has ever been applied to the pack)?
I'm now wondering do I replace the discharged cells and the BMS?...
- 13s3p (48V, 9Ah nominal)
- Brand new Sony VTC6 (3Ah) cells (were all reading 3.8xV when I built the pack)
- 45A BMS
- 8mm/0.2mm nickel (1 strip per parallel bank. 3 strips per series connection)
Thanks!
Bummer... Why?!
- 45A BMS
Thanks!
