DKD battery indicator
tedo
florida
This DKD always shows full. Should the battery indicator have come down yet? I set it to 96v, but also did the "manual calibrate" at 96v. See pic. Actual is still shows 104.9, but my battery capacity on fardriver shows only 77%.
I have read about this somewhere and can not find it. I have a QS hub and my fardriver insist that my Max RPM is 3000. When I change the "pro mode" settings to 1670 it mathematically lowers to the equivalent of 55% of 3000 on the "simple mode" page. If I change the simple mode back to 100% it gives me 3000 on the pro page. It does this with the 800 line amps and 1800 phase amps also. See pics it will make more sense. Should I just leave it alone like it is in the pics?
So looks like 10 bars. Assuming you set “it”means the nominal voltage of the battery, then I think thats 26s. if it’s a lithium pack, then full charge is 109.2v. So 104.9/109.2 = 0.961 or still 96% charged. Might not have reached the voltage to go down a bar.
Not sure what’s going on with the controller and the 77%.
Oh ok. That makes sense. Not sure which indication to believe. Looks like 77% is the outlier
The battery bar finally dropped 1 line at 73% and is still there at 66%. LOL. I think it is just not accurate. OneLin connection.
Maybe they sent you the 84V or 72V version of the display by mistake.
It showed 96 when tlI went to set the volts. I did figure out setting the bit rate to "6" made the amps bar work. Although I think the bar caps at 110 so not that useful.
