synics
- Joined
- Apr 3, 2020
- Messages
- 109
Jonno said:Like this?
A 1000lb pit bike shock 280mm - much better![]()
https://www.ebay.co.uk/itm/Pit-Bike-Rear-Shock-With-Piggy-L-280mm-1000-lbs/283558401950?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Note to self - clean bike!
Hey man, I ended up buying this shock, DNM MTG-RC, 295mm with 900lb spring. Man this thing is a BEAST, HUGE! It actually weighs 5.8lbs, with an oil can the size of a red bull can. LOL
So now I need to find flat mount suspension shock mounting brackets that accept 10mm since that's the inner diameter of the mount hole. All the ones I'm seeing out there are 1/2" which is 12.7mm. Why the heck do they use these weird sizes. I assume if I used an M10 bolt with a 12mm outer busing it would still have some play in it. How did you solve this problem since your shock has the same size mount hole?
