Iron Yeti
My bike is going to be here on Monday. I am bound and determined to learn how to build and maintain a bicycle so I decided to invest in some tools. From reading around online this is what I gathered for tools that I will need.
-15&19MM Cone Wrench: $14.15
-Alan Key set # 2, 3, 4, 5, 6, and 10 mm 1/4 -7/32 - 3/16": $9.50
-Phillips head screwdriver: $2.49
-Flathead screwdriver: $3.18
-32/36mm headset wrench: $16.95
-Triple Spoke Wrench: $7.29
-Adjustable wrench x2: $20.44
-9/11mm wrench: $4.74
-8/10mm wrench: $4.74
-Tire Lever: $2.49
-Lube: $4.23
-Patch Kit: $3.18
$93.38
Here is a full list of recommended tools. I only picked the ones I thought absolutely essential for now.
PW-3 Pedal Wrench 15mm and 9/16
CWP-6 Crank Wrench and Puller
HCW-15 Head and Crankset wrench 32-26mm
CT-3 Screw Type Chain Tool
SCW-SET Shop Cone Wrench 13mm to 19mm (or save by buying only two, usually 15&19)
CCW-14R Cotterless Crank Wrench
SR-1 Chainwhip/Freewheel & Lockring Remover
BBT-2 Bottom Bracket tool (or adequate model to your BB)
CN-10 Cable and Housing Cutter
SW spoke wrench (check dimension you need)
BT-5 third hand.
A pair of adjustable wrenches
8 to 11mm wrenches
Flat & philips screwdrivers
Set of hex wrenches
Anything missing?
-Tire Lever: $2.49
-Lube: $4.23
-Patch Kit: $3.18
$93.38
BT-5 third hand.
8 to 11mm wrenches
Set of hex wrenches
Anything missing?
