GreatScott!
Hello,
Not sure if this topic has already been done but I am looking for some advice on how to connect a doc watson meter to a 48v SLA battery pack system, I can't get it to work.
On these meters, there are a four wires to account for in total.....two wires, a black and red wire coming from the left (Source) side of the meter and two other wires, black and red again coming from the right (load) side of the meter. I am using an alltrax golf cart controller, I first tried to connect the Red (positive) wire from the source side to the main power wire from the battery, I did this at the controller + tab. I also connected the RED + wire from the LOAD side to this same location. I then connected the BLACK, negative wire from the SOURCE side to the negative terminal wire of the battery where it is connected to the controller tab, I also connected the BLACK negative wire from the LOAD side to this same location, essentially connecting the meter across the battery. This doesn't seem to work as it only displays overall pack voltage but I get no other readings such as KW and Ah etc. How is this thing supposed to be connected?
cheers.
Jonathan-
cheers.
Jonathan-
