ebikedelight
- Joined
- Dec 25, 2014
- Messages
- 307
teslanv said:Use 12AWG Silicone or PTFE for better "Punch". On my MXUS 3000W Hub Phase wire upgrade I am actually using 8AWG, and the performance boost is nice.ebikedelight said:Thanks for all the info guys,.
For upgrading the 5 phase wires and 3 sensor wires , coming directly out of the AXLE , to take 72 volts - 40 amps wouldnt 14 gauge wire be thick enough ? The wires they use now, is very thin...
does it matter if it is stranded or unstranded wire ? I assume it has to be stranded so it is flexible enough to wrap the individual insulated wires tightly around each other in a braid style to reach the controller ?
is this the stuff I need
http://www.ebay.com/itm/12-2-AWG-Gauge-Marine-Grade-Wire-Boat-Cable-Tinned-Copper-Flat-Red-Yellow-40ft-/131447270276?pt=LH_DefaultDomain_0&hash=item1e9ade2b84
also, if i just attach the thicker wires at the exit point of the axle, wont the thinner wires that are still inside the ehub/ axle, be at severe risk of burning up with 72 volts - 40 -60 amp ?
