izeman
1 GW
this ask for help goes out to all the guys who know how to draw a quick schematic and board layout.
for two days i tried to make one board which should be uploaded to osh park for making, but i just can't handle eagle or diptrace good enough to make it happen. i watched several tutorials, but the result is never as expected
i downloaded the jst-xh connector library, but as soon as it comes to traces on the board it get's weird.
in short words: maybe there is someone out there who can do me a favor and make this for me?? it doesn't have to be perfect, and i guess as soon as i have something to work with i can refine it to my needs.
it's quite simple: 4x xt60 male plugs soldered to the board in parallel. orientation doesn't matter. trace should be as fat as possible. solid wire will be soldered on bottom of the board for higher amps.
6x jst-xh6 soldered in parallel. orientation (pin1 up or down) doesn't matter. why 6? because the 5th one will go to the bms, and the 6th one will be a monitor connector for a celllog.
this is what it should look like - more or less. the smaller the better, as long as you can pull the connectors from the board.
4 small mounting holes 3-4mm in diameter on each edge.
2-sided routing is fine. but only 2 layers. not more.
THANK YOU VERY MUCH IN ADVANCE!!!
