I thought ebikes with hydraulic disc brakes use mineral oil for brake fluid. I was surprised to find that my Fly-7 E-moped https://www.flyebike.com/product-page/fly-7 use DOT-3.
How common is that?
How common is that?
That seems a bit excessive. If its not broke don't fix it.I am thinking of removing the calipers every 6 months ( 2 bolts) to clean and lube the pistons.
What ever fluid brakes take. DOT 3.What kind of lube should I use to keep the rust away?
When installing new brake pads, apply brake lube to the outside of the pads (where they slide into the caliper housing) and the caliper slide pins, but avoid getting it on the friction side of the pad where it contacts the rotor.
Important to clean and lube those pins.The part that allows the brake caliper to slide, ensuring even wear of both brake pads, is called the caliper slide pins or guide pins.
What is Google AI? OK Marty that's enough copy and paste.Brake lubricant, also known as brake grease, is a specially formulated grease designed to lubricate moving or sliding components in a vehicle's braking system, ensuring proper operation and preventing noise and premature wear.
Frozen caliper pads locked rotor can't be removed (caliper hits the rim on this moped). I spent 20 minutes trying to get it off. Unfrozen, caliper comes off in less than 1 minute by undoing 2 bolts. Much easier to service it on a schedule before it breaks.That seems a bit excessive. If its not broke don't fix it.
Unless you have researched the seal compound and know for a fact that it will resist lubricants, this is dangerous. Many elastomers will be damaged by the volatiles in lubricants.lube the pistons
When I said "lube the pistons", I did not mean to take the pistons out and lube the entire thing, only the portion exposed to the elements (beyond the seals), to keep rust from developing. If done every season, I think will lower the incidence of frozen calipers.Unless you have researched the seal compound and know for a fact that it will resist lubricants, this is dangerous. Many elastomers will be damaged by the volatiles in lubricants.
I specified engineering chrome platings - we stated "hard, dense, fine, satin-finish chromium plate". Shiny chrome is mirror-finish because it is so thin. Appearance chrome plating is crap.
Can you cite some scientific studies?Mineral oil in a DOT 3 brake will cause no trouble.
Don't forget rust on walls of hole that piston fits into. If you having frozen caliper paranoia? There is medication for that.When I said "lube the pistons", I did not mean to take the pistons out and lube the entire thing, only the portion exposed to the elements (beyond the seals), to keep rust from developing. If done every season, I think will lower the incidence of frozen calipers.
Sorry . . . Honestly can't remember where that knowledge came from.Can you cite some scientific studies?
I don't think you understand the purpose of "scientific studies". No one will guarantee that mineral oil will work with every single DOT brake system, because noone's going to to test them all. At the same time, there are no good reasons why it wouldn't; DOT is more corrosive and systems that use it use rubber seals that can withstand it. By extension, they will generally work fine with mineral oil - at the cost of much lower maximum operating temperature.Can you cite some scientific studies?
I think the low price of this particular model is because it's been in production for many years (at least 10). It's the most common delivery ebike in NYC with a big network of dealers to keep them running. For $995 (SLA battery) you get:Considering that your contraption is a facsimile of a motor vehicle and will tend to use those standards, my best guess is that you're only dealing with low component quality (cheap materials, poor finishes, thin platings) rather than some more fundamental issue. Given that you paid less than $1000 for it, that's no surprise at all. You got yourself a scooter-shaped object.
Features | Remote Key Fob Alarm System Lockable Under-Seat Storage Front and Rear Suspension Full Lighting Package Arrives Fully Assembled |
Motor | 1500W/BRUSHLESS |
Battery | 60V/20Ah Lead-acid battery 60V/50Ah Lithium-ion battery 60V/55Ah Lithium lon Battery |
Range | 60/20Ah (Lead-acid) : 20-25miles 60V/50Ah (Lithium-ion): 55-65miles 60V/55Ah (Lithium-ion): 60-70miles (Mileage may vary depending on rider weight and road conditions) |
Top Speed | 30MPH |
Charging Time | Lead-acid Battery: 8-10 Hour Charging Lithium-ion Battery: 8-10 Hour Fast Charging (Will take 12 Hours if voltage is low ) |
Payload Capacity | 350LB |
Brake | DISC/DISC |
Tires | 10x3.0" |
Headlight | YES |
Taillight | YES |
Turnsignal | YES |
Rear-view Bike Mirror | YES |
Charger | YES |
Back Seat Step Pegs | YES |
I didn't think you were!To be clear, I'm not advocating mixing fluid types.
Yes.I didn't think you were!
Have you converted DOT-3 brakes (filled with DOT-3 initially) to DOT-5?
Just refill, no flush with DOT 5? What benefits did you notice?Yes.
A simple drain and refill.
What vehicle did you do that on? Any issues? What benefits were you expecting (switching from DOT 3 to DOT 5)?Refilling is a flush.
