Chalo
100 TW
I'd like to reiterate that DOT 3 and DOT 5 are incompatible fluids and should never be mixed with each other.
Maybe as best practice? But silicone doesn't interact chemically with glycol, mineral oil, or seals for either fluid. In practice, it can be contaminated with either one without ill effects as far as I've seen (assuming the other fluid is compatible with the .
hydraulic system).
In the cycling industry, Main Street pedicabs use a Magura rear brake lever (designed for mineral oil) with a racing kart caliper (designed for glycol) with DOT 5 silicone fluid. In this implementation, it is important that neither glycol nor mineral oil is introduced to the system because the seals at one end or the other could be affected.
