wiredsim
I've been a long time reader of this site and infrequent contributor, as I haven't had the time are money I would like to have had to put in to this hobby. However I recently acquired a used scooter from Craigslist and I need some new batteries for it. Here is my thread about it in the Scooter forum. I had some SLA's from a UPS, but they appear to be useless at this point. The scooter was designed to use 3x12volt 9ah SLA's and has a 36 volt controller with a 31.5 volt LVC (so the label says anyway).
Since decent replacement SLA's would run me at least $60 I've been looking at moving to a better battery chemistry. Long range isn't as important to me as performance, ease of charging and longevity. Plus I know that at 25 amps I wouldn't be getting 9ah out of those SLAs anyway. I'm leaning towards a LiPo pack, as I need to get a charger either way. My first though is to put in a 5S and a 6S pack of the same capacity for a combined 11s so that the LVC runs in a safe range for the pack. But I don't know if the fresh off the charger voltage would fry my controller. Would a 10s pack suffice with a 31.5 V LVC? Can I drain these to 80% DOD or lower and still get a decent cycle life? Do I have to use a BMS?
My other thought is to get some Bosch 36V Fatpacks, which at around $80 a 2AH pack is more expensive, however the charger is only $40, I don't have to worry about exploding packs, there is a basic BMS provided and they seem to be able to handle a high DOD and still give good cycle life.
So $200 for a Bosch 4AH pack plus charger.
Or
10s1p Lipo pack plus a charger like the GT A-6 for about $120 total.
LiPo comes out better with higher capacity and lower cost, but if I can't use as high of DOD then that extra capacity may not mean much to me. Also I'm not including any prices for BMS on the LiPo and the cycle life is going to probably be better on the Fatpacks.
Well I'm putting together these prices as I write this out and SLA is still coming out as the cheap way to go of course but the LiPo's aren't bad either. Is there any better budget lithium alternatives? I haven't found a source for used power tool packs in my area yet. I guess my big question is if I could just drop a 10S pack into my scooter and trust the existing controller to handle it? Anyone else make this upgrade?
Thanks!
Or
Thanks!
