Dual 1000w hub motors
GodsWarrior
My hub motors shake, rattle when i hit full throttle....and my battery was @ 30 perc. Does this mean my battery too low to power both or even 1 motor????? On single motor it was slower than normal..........i need your feed back guys.,thanks.
If you are hitting LVD and you have a sorta cruddy controller, that could happen. The droop could make the LVD cut in, which causes the voltage to rise, which causes the LVD to disengage and the thing to go to full throttle, which causes the voltage to droop, which causes the LVD to kick in . . . .
Tell us what you have, did you buy it or make it?
Home made stand up scooter. 52v 28ah battery ...dual 1000w tx 10" hub motors. I purchased dual 1000w 35amp one throttle controller kit from ali express and ...so today i took it for a ride everything was good until on my way back took the street full throttle ...and when i got home i noticed the motors making a wierd noise on dual mode ,and single mode the motor was slower weak( to pick up speed) when i gun it in dual mode they make a rattle-ing shaking noise and no movement then i eas-off throttle and very slowly pick up speed and once im moving it seems to do better .....i have doubts about these controllers ima swap them out for a single 1000w controller to do some tests to make sure motors are ok..
Well i swapped the dual controllers for a good working single and the problem persisted...its not the dual controllers...i opened up battery and peeked inside to look for faults. And nothing...so ..my friends....i belive the hub motors went south....man ..that sux...
