That's a pretty massive pulley! Good thing you had means to lighten it up a bit. I'm assuming that's the "big" one, at about 44t, and that the drive pulley is about 22t. That's what it looks like from the CAD images.
What version of 8mm pitch belt are you using? There's a million and one tooth profiles, but I would expect you to be using either the P8M or the (EV)8YU. And belt width? I'm most curious since I'll be doing another Transmag build soon. I've used EV5GT (5mm pitch, 9mm width) before for an RC drive experiment, but the power levels were MUCH lower and the RPM about double what yours is likely to be.
For those who are unfamiliar with MISUMI, get familiar! Awesome site to use if you don't have ready access to machining of shafts and pulleys and such, as long as you're comfortable with metric sizing. They have great belt selections, have pretty much anything available for download to CAD, and, perhaps most importantly, very good documentation on specs. Here's their pulley/belt specification sheet: http://us.misumi-ec.com/pdf/fa/2010/p3515-3536.pdf
Assuming a EV8YU belt, 20 mm wide, your design power handling is about 6kW continuous, so you should be good with the TransMag. It does put that in the sort of 'questionable life' region of the chart because your RPM is high and the small pulley tooth count is so low, but for an eBike (as opposed to industrial equipment) the life you'll get will probably be very good.
Looking forward to more updates!
