e-bicycle legal requirements sections ??
norfolk, uk , england
has any one ever thought that it might be useful to have a section where the legal requirements for electric bikes are posted and sorted by country and where appropriate the county of the country ?
im sure there is a lot of confusion with some new users on this matter ,, i have friends that seem to think that as long as the power is 250w or less then the bike is legal in the uk with out mot tax and insurance, , but the truth is that the bike must be no more than 200w and must have pedals. also must not be heavier that 40kg with batteries ..
also if the bicycle is fitted with electric then
the bike must have a plate showing the manufacturer, the nominal voltage of the battery, and the motor’s power output
http://en.wikipedia.org/wiki/Electric_bicycle#Legal_status
Australia
In Australia the electric bicycle is defined by the Australian Vehicle Standards as a bicycle that has an auxiliary motor with a maximum power output not exceeding 200 W without consideration for speed limits or pedal sensors.[12] Each state is responsible for deciding how to treat such a vehicle and currently all states agree that such a vehicle does not require licensing or registration. Various groups are lobbying for an increase in this low limit to encourage more widespread use of electric bicycles to assist in mobility, health benefits and to reduce congestion, pollution and road danger. Some states have their own rules such as no riding under electric power on bike paths and through built up areas so riders should view the state laws regarding their use. There is no licence and no registration required for electric bicycle usage.
As of 30 May 2012, Australia has an additional new electric bicycle category using the European model of a "Pedelec" as per EN15194 Standard. This means the bicycle can have a motor of 250w continuous rated power which must be activated only by pedalling (if above 6kph)and must cut out over 25kph. The State of Victoria is the first to amend their local Road Rules to accommodate this new standard as of 18 September 2012.[13]
Canada
Eight provinces of Canada allow electric power assisted bicycles. A three-year trial in Ontario ended October 2009. In seven of the eight provinces, e-bikes are limited to 500 W output, and cannot travel faster than 32 km/h (20 mph) on motor power alone on level ground. In Alberta the limits are 750 W and 35 km/h (22 mph).[14] Age restrictions vary in Canada. All require an approved helmet. Regulations may or may not require an interlock to prevent use of power when the rider is not pedaling. Some versions (e.g., if capable of operating without pedaling) of e-bikes require drivers' licenses in some provinces and have age restrictions. Vehicle licenses and liability insurance are not required. Generally they are considered vehicles (like motorcycles and pedal cycles), so are subject to the same rules of the road as regular bicycles. In some cases regulatory requirements have been complicated by lobbying in respect of the Segway HT.
Bicycles assisted by a gasoline motor or other fuel are regulated differently than ebikes. These are classified as motor cycles regardless of the power output of the motor and maximum attainable speed.
China
In China electric bikes currently come under the same classification as bicycles and hence don't require a driver's license to operate. Previously it was required that users registered their bike in order to be recovered if stolen, although this has recently been abolished. Due to a recent rise in electric-bicycle-related accidents, caused mostly by inexperienced riders who ride on the wrong side of the road, run red lights, don't use headlights at night etc., the Chinese government plans to change the legal status of illegal bicycles so that vehicles with an unladen weight of 20 kg (44 lb) or more and a top speed of 30 km/h (19 mph) or more will require a motorcycle license to operate, while vehicles lighter than 20 kg (44 lb) and slower than 30 km/h can be ridden unlicensed. In the southern Chinese cities of Guangzhou, Dongguan and Shenzhen, electric bicycles, like all motorcycles, are banned from certain downtown districts. There are also bans in place in small areas of Shanghai, Hangzhou and Beijing. Bans of scooter style electric bikes (SSEB) were however cancelled and in Shenzhen electric bicycles may be seen on the streets nowadays (2010–11).
European Union
European Union directive 2002/24/EC exempts vehicles with the following definition from type approval: "Cycles with pedal assistance which are equipped with an auxiliary electric motor having a maximum continuous rated power of 0.25 kW, of which the output is progressively reduced and finally cut off as the vehicle reaches a speed of 25 km/h (16 mph) or if the cyclist stops pedaling.” This is the de facto definition of an electrically assisted pedal cycle in the EU. As with all EU directives, individual member countries of the EU are left to implement the requirements in national legislation.
European product safety standard EN 15194 was published in 2009. The aim of EN 15194 is "to provide a standard for the assessment of electrically powered cycles of a type which are excluded from type approval by Directive 2002/24/EC".[15]
Israel
In Israel, persons above 14 years old are allowed to use electric assisted bicycle with power of up to 250W and speed limit of 25 km/hour. The bicycle must satisfy the European Standard EN15914 and be approved by the Standards Institution of Israel. No license or insurance is required. Other motorized bicycles are considered to be motorcycles and should be licensed and insure as such.[16]
New Zealand
In New Zealand, an electric bicycle is considered to be a 'Power-assisted cycle'. A power-assisted cycle is a cycle that has a motor of up to 300 watts. The law treats these as ordinary cycles rather than motorcycles. This means that it is not necessary to register or license them.[17]
Norway
In Norway, electric bicycles are classified as ordinary bicycles, according to the Vehicle Regulation (kjøretøyforskriften) § 4-1, 5g. Hence, electric bicycles are not registered in the Vehicle Registry, and there is no demand for a license to drive them. Still, there are constraints on the bicycle construction. The maximum nominal motor power output can be no more than 250 watts and the maximum performance speed of the vehicle when the engine is running is 25 km per hour (15 mph).[18] A function that reduces motor power when vehicle speed exceeds 25 km per hour is mandatory. However, if the motor is not running, the electric bike, or any other bike, answer only to the constraints of the ordinary speed limits.
United Kingdom
In the United Kingdom, electric bicycles are classed as standard bicycles providing the motor's maximum continuous rated power output does not exceed 250 W,[19] and cuts out once the bike reaches 15.5 mph (24.9 km/h). It must also be under 40 kg (88 lb). This means the rider does not require a license to use them, however riders must be at least 14 years of age.
United States
Federal law in the United States states that an electric bicycle must have a top speed when powered solely by the motor under 20 mph (32 km/h) and a motor which produces less than 750 W (1.01 hp). They are not considered motor vehicles by the federal government and are subject to the same consumer safety laws as unassisted bicycles.[20] Their legality on public roads is under state jurisdiction, and varies. See the main Electric bicycle laws article for details on the law in individual states.
In addition to federal electric bicycle laws, the state of Illinois added that the operator be at least 16 years of age. A license and registration is not required.[21]
New York State law bans motor-assisted bicycles from state roads and city streets, though the ban is not currently enforced and a bill is under consideration to allow electric bikes with a top speed of 20 mph (32 km/h) and less than 1,000 watts of power.[1][22]
this is the sort of thing i meen m8 .
the one you posted states
United Kingdom
but on the government site is says
Electric bikes meeting the requirements are called ‘electrically assisted pedal cycles’ (EAPCs). They can be 2-wheeled bicycles, tandems or tricycles.
EAPC requirements
The requirements are:
the bike must have pedals that can be used to propel it
the electric motor shouldn’t be able to propel the bike when it’s travelling more than 15mph
the bike (including its battery but not the rider) must not be heavier than 40 kilograms (kg) if it’s a bicycle, or 60kg if it’s a tandem or tricycle
the motor shouldn’t have a maximum power output of more than 200 watts if it’s a bicycle and 250 watts if it’s a tandem or tricycle
this information is from the official gov web site https://www.gov.uk/electric-bike-rules
thats the problem, the uk government dont want us to have nothing for nothing ,they want money for what ever we do,
i weigh in at 290pounds or 20stone, 200w is no good for me what so ever.
then there is the problem of home made/ converted e-bikes. because every e-bike must have a plate showing the manufacturer, the nominal voltage of the battery, and the motor’s power output
what do we put on the plate as the manufacturer?? :cry: :cry:
Miles said:
http://www.pedelecs.co.uk/forum/electric-bicycles/13377-approved-ebike-list.html
that is a very interesting thread ,, thank you ,,
i think they are going round in circles on it though as the laws are very clear on what is allowed and what isnt ,, but i know people. that when you tell them the uk laws think i am just lieing about it ..
thank fully the police have better things to do at the moment ,, but as is becomes obvious to those to be ,, that more and more e-bikes are being used ,, then the police and government will start to take real notice, especially when they realize that more than half of the bikes should have insurance , mot and tax ,, they will think of the money they can get more than what is really useful for adults need to use the bikes ,,
200w is a stupid law ,, that will hardly scrape the skin off of my rice pudding ..
the other problem is if you go into the city/town centre, then there are not really that many places you are allowed to leave a bike ,, which in this day of pollution , there should be more places ,, what happened to the days when we used to lock our bikes to a lamp post or a fence only yeards from the shop we were going to ,,..
Lots of other sites have links to the local ebike laws in many locations, US states, whatever.
Invariably, they are full of misinformation. Often they " summarize" the local vehicle codes and in the process misinterperet them. The most glaring bit of misinformation out there of all, is that the Federal Ebike Law has anything whatsoever to do with the legal status of an ebike when operated on the public streets in the USA.
THE ONLY GOOD SOURCE FOR THIS LEGAL INFORMATION IS YOUR OWN LOCAL MOTOR VEHICLE LAWS AS STATED ON OFFICIAL GOVT WEBSITES OR PUBLICATIONS.
In particular, don't trust the legal advice of ANYBODY selling ebikes or kits. Only the official govt information source will contain ALL the statutes that apply to you. The million sites that try to "explain" the law oversimplify them, and invariably mislead you on the actual legal definitions of bike, ebike, moped, bicycle with helper motor, motorcycle etc. Figuring out if you are a bike or a motorcycle can be tricky.
There are simply too many laws out there for anybody to summarize them accurately. In the USA in particular, it varies from state to state, and in addition there can be county, city, or village ordinances that apply localy as to if an ebike can be ridden on the sidewalk, the bike path, etc etc.
The law is very simple where I live in New York state USA. Electric bikes of any sort are expressly ILLEGAL! Yet NY City is full of them.
Hopefully the new 1000 Watt law that is on the state senate floor will be passed in the next session.
The US government gave 1 billion dollars to help various EV start up companies bring electric cars to market, none of which can accomplish anything unless they cost $40,000. E-bikes with a top speed of 35mph are a much more practical, and achievable solution for electric travel and should be promoted as the first choice for "early" EV production.
They really should !
I hope it passes for you. :)
Who killed the E-bike,
regulations.
How can anything get a start nowadays if the government is going to step in and squash it. Yeah, sure, you can have your E-bike, just attach this anchor.
What's up with the low wattage limits when there is also a speed limit. Heck, allow the bike to have a thousand watt output if the speed is limited. At least then, it can haul a heavy person or heavy load.
I mean, if they are trying to encourage people to use alternative transportation, they have to at least make it a somewhat practical alternative.
It's hard enough to sell a E-bike because of cost, battery maintenance, weight... Then, on top of that, a speed limit that makes a regular bike more attractive. I wouldn't bother if my E-bike choice was 15 MPH at 250 watts. And a lot of people don't.
I KNOW WHAT YOU MEAN M8 ,, opps caps ; i have a 800w scooter but i weigh 20 stone ,, i dont mind the speed limit as i just need the bike to get around ,, i have C,O,P,D of the lungs ,, i dont want a mobility scooter as i dont think they are safe on the roads or the paths ,, i have seen to many of them nearly topple over because of a curb, on top of this they can not go into the country side ,,
besides i have always wanted a electric bike ,, i love the technology of them ,
i wonder if the laws are actually set up so that they can tax us on them more than any thing ..
its no wonder so many put bigger powered motors on their bikes ,,
Happily for me, the New Mexico (USA) law is also pretty simple. Anything with pedals and a motor of any kind is a moped. No vin required, no rules about lights and signals other than the regular bike rules, valid drivers licence required. 30mph top speed, 49cc limit. Since 49cc's can easily mean 5hp, I figure up to 3750 watts is legal. Technically, the IS NO watt limit. :twisted:
I think it's a good compromise, you can have enough power to get up a hill, but not enough speed to need DOT tires. 20 mph is too slow, so many people can pedal faster, so why limit the out of shape to slower?
This law is how I got interested in slow windings. Put 72v on a regular hubmotor and you are going near 40mph.
I have Washington State, USA laws pertaining to Bike & EV listed at the bottom of my 2WD Garden Wall page; the link is in my sig. Do we want to add state/provence regs to the wiki?
~KF
Certainly--add as much detail as you wish.
Yes, go for it. You'd be one who would get it correct.
I'm just sick of the typical vendors who quote the law for selling an ebike, and tell customers they can ride with no reference to local motor vehicle statutes. For example, in NM, you DO need a valid drivers licence. Happily the cops could give a damn usually, but that is what they can charge you with if they know and hate you.
Gentlemen -
Thank you for guidance. I have updated the wiki. Please let me know if this is sufficent. :)
Best, KF
not directly related but has links and good regulr biek law info
http://bikelaws.org/
https://www.dmv.ca.gov/portal/dmv/detail/motorcycles/motorcycles
When I got my kit, I first researched the Cali state law because the last thing I need is trouble with the fuzz. It goes around 23-25 mph on a hot charge mainly due to the large diameter balloon tires so technically it breaks the 20 mph limit, anyway that's plenty fast for my old carcass. I don't really want to become a skull & cross bones on the side of the road. :twisted:
More than likely I'll stay at 36 measly volts in the future. Going to 48 volts would almost certainly get me busted, due to the large number of bored lazy cops and the lonely hours I ride. At the speed I'm already going the freewheel buzzes like a giant bumble bee, it makes way more noise than the front DD hubmotor. I'm expecting the freewheel to bust at any time and leave me with useless pedals or causing it to violently morph into an instant fixie. :lol:
