E-bike powered by disposable vapes
harrisonpatm
Moderator
Staff member
Michigan, USA
What a terrible idea. I love it! So many reasons why you shouldn't do this kind of battery build, but it's clever idea. Especially since vapes tend to require high-discharge cells anyway. As long as you don't expect your pack to have a very long lifetime...
I both love and hate that lithium batteries are so cheap that you can make 'disposable' things and wantonly throw them away.
I think there are some legal initiatives in the EU recently that either suggest or demand that industry re-use cells.
Some interesting things coming out of that, but.. i think you shouldn't go so far as to make a vehicle with questionable battery safety.
Oh yeah, this is wildly unsafe. I would have personally used my IR meter, capacity tester and a high grade adjustable voltage/current charger to baby these cells as much as possible.
I just wish the video creator had done as many critical steps as possible for safety.
I have two destroyed "hoverboard" batteries (10s2P) that I'm having a hard time disposing of because the casing on some cells has been breached. And I live in a large metro area. I'll probably end up having to disassemble the battery so that I can drop the intact cells off for recycling. And the destroyed/breached cells will probably end up in a landfill somewhere.
Wildly unsafe? That seems a bit harsh. I'm pretty sure that the cells he's using don't have the safety mechanisms common with modern 18650 cells. So I certainly don't think this is a "safe" implementation. But he at least did a decent job of building the battery with an appropriate BMS, reasonable shock protection and insulation and a decent case and monitoring system. He even made a point to warn others against copying what he did.
In the end I think it is a decent video for its intended purpose - raising awareness of the wasted resources being used in the vapes.
Exactly this. I would call it "moderately" unsafe, rather than wildly. He does use a BMS, at least. But i did mostly want to share the video because it highlights the level of things that can be made or repurposed from stuff we throw away.
I was indeed too harsh :p
I should perhaps review my statements before posting them.
Those are 20400 lithium cells. Do they have thermal circuit interrupts and/or vents like most 18650's? Since they are never meant to be recharged (disposable), I hope there is something like a CID or vent.
Those vents and CID's in my packs have saved my bacon.
The guy who made the video requested and received a data sheet on them. That sheet said that the cells could be recharged not less than 300 times. I've seen other 20400 cells claiming 500 cycles.
I wonder whether all of the batteries used were from the same maker or not. Seems unlikely that they would all be identical. OTOH, with a YouTube video you never really know how things may or may not have been fudged.
I could not easily find any info on vents or circuit interrupts 20400 cells. These are sold for the purpose of powering consumer electronics - so maybe?
I've said it before and I'll say it again. It's going to become more and more important to lean how to make/use things utilizing scrap and waste.
Always has been. ;)
Some of us are forced into it to do the things we want / need to do, so we do it by nature, but most people have to learn to do it, or "force themselves" to do it.
I agree, we're kind of repeating the historic sequence of events from the 1920's all over again.
I like these two 'refillable' batteries coming out of Europe lately. I'm waiting on these companies to produce ones in larger capacity, after that, i'm never buying a conventional battery again.
