deronmoped
- Joined
- Oct 6, 2008
- Messages
- 706
I have a 36VDC brushed motor, Lithium battery with BMS and 36VDC controller.
This bike is not stock. I installed the controller and battery pack. The combination has worked great for probably a year now. Just recently the bike started shutting down when applying power. At first it would happen randomly, now it shuts down fairly consistently only after using power for a minute or two. The only way to get the power back on is to disconnect the battery pack/BMS combination from the controller. Then the bike powers up normally, until it does the same thing all over, that is, shuts down after being under power for a minute or two. It shuts down when I reapply the throttle after backing off to brake or shift gears.
What I tested so far:
I pulled the battery pack/BMS out of it's case and checked individual battery voltages and total voltage. They looked good. I looked for burned parts on the BMS and did not see any. I tried loading the battery pack up with automobile car headlights, but that was inconclusive.
I also took a look at the controller and did not see any burned parts or loose wires. All the other functions on the controller work, that is, power switch, brake switches and power indicator.
If I was to guess, the controller is sensing a over-current condition and is shutting down wrongly. What have experienced in the function of the bike is, the shutdown does not occur because of too much load. It shuts down without getting to full throttle or the bike being loaded heavily.
It could be the BMS too, sensing a overload.
I would hate to start throwing parts at it and I'm not set up to bench test 36VDC items, to determine if it's the battery pack or controller.
Anyone got any ideas?
Thanks, Deron.
Thanks, Deron.
