So I recently built a 1500W ebike from a kit from Alibaba and everytime I start from a complete stop, it makes this vibrating sound. Once I get going it only makes a normal humming noise and acts normally. It doesn't stutter and I feel like there is nothing wrong with it in terms of torque and power.
Here is a video of a start. As you can see, once I get going its very silent: https://www.youtube.com/watch?v=8eQDwkZEXeo
The controller and the motor came in the same kit and thats why I hooked up the 3 phase wires color by color. The hall sensor wires are all wired up to a 6 wire connector which in turn connects to a connector on the controller.
So should I be worried and rewire the hall sensor? Or is this normal?
The controller and the battery are in a metal case in the frame which is hard to open, so here is a photo during the build process of the inside, https://imgur.com/EkWYwtx , the most left two connectors (yellow and white) are the motor connectors.
