PeteCress
What are the outdoor temps where you live, and will you be running the battery under a CycleAnalyst?maydaverave said:I got my e-bikekit today and installed it on a old bmx looking single speed small tube 26" frame. I went with the 9ah battery, so far so good. After I put a some more shallow cycles on it I will check the range. I have 1.5" tires at 60 psi and I am hoping for 15 miles but only time will tell.![]()
If you're in the forties (F) or lower, I'd be interested in hearing how many AH you get out of the battery in real-world use.
So far, my highest from the same make/model has been 8 AH at about 52 F. Some have said that I must have a bad batt, but I'm still not so sure bco the temperature factor.
