E bikes for Dummies
tom2slow
Hi All,
Is there a place when one could sit and get enough knowledge to be dangerous around here? Sort of an 'for Dummies' book or section?
I am reading about different motor types, controls, regen braking and batteries and have acquired a head ache :))
--T
Yeah, unfortunately a lot of info in that section is growing a bit long in the tooth.
And a lot of it is written by people that are um... smarter than the average bear :lol:
We are lacking a lot of information on geared motors, non-high performance stuff, lipos, etc. which are all becoming very commonplace.
My suggestion to you is to lurk on the board for a while and read. That's what i did for my first month or two. It was real hard coming into this with basically no electronics experience.. :p. If you have any questions feel free to PM me, or hell, just start a thread..
Yeah. Ask questions. Even dumb ones. A lot of brilliant ideas have come from some dumb questions.
Ebikes aren't a mature techniology. The technology is still in the pioneering phase, and most of the pioneers have found their way to this forum. There's plenty of questions no one has even though to ask yet.
^-- i think that's one of the reasons. We are just starting to exit the tinkerer stage. When i came on here about 5 months ago, there weren't a ton of newbies, geared motors were a joke, hobbyking stuff was kinda new, A123 cells were still a big deal, ETC.
Who knows what will be the next big thing in 6 months to a year.. there's a reason why i read this forum multiple times a day :p
EDIT: this post was copied to a permanent home in the technical reference section: http://endless-sphere.com/forums/viewtopic.php?f=16&t=26619. Check that link for the most up-to-date version. It is one of the links in the new Ebike General discussion FAQ (http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=26488).
As a newbie myself, who has been reading and keeping notes for a couple of months and think I am beginning to understand things, I'll share my notes, as somewhat of a "dummy" guide. This is a basic outline, not from experience (my components are ordered/being shipped), but just my summary of what I think I hear as the majority opinion here. But as others said, things change fast. YMMV, literally.
These notes are mostly about an ebike conversion, as opposed to buying a commercial ebike, but many of the same concepts apply.
In an ebike conversion, the major components are the bike, motor, controller, batteries, and the rider's needs/wants. The last one is the most important, but a little technical detail is needed to make sense of that, so the others first:
1. The Bike
Anything goes, really, but steel or cromoly is generally preferred, especially for the forks, especially for a motor on front forks. Use a magnet to assess; it will stick to steel or cromoly, but not to Aluminum, carbon, etc. No suspension on the front forks if using a front motor.
The bike needs storage for the batteries. A rack on the back is probably the most common choice; batteries in the frame triangle require a custom box/bag (no good solution there yet really).
2. Motor
A brushless hub motor is the main choice. Other types (through separate chain, friction drive etc) are not for dummies, but if cheaper is key then you could look into them.
In brushless hub motors, the two types are geared or direct drive (DD).
Geared hub motors have a fixed internal gear ratio which allows the motor to operate at a more efficient higher motor speed for a given wheel speed. Geared motors are lighter, and have better torque at low speed, but no regeneration is possible. They are not as good for very high power, typically, as the gears can be damaged. Makes a slight whining noise. They freewheel, that is, they give no drag when pedalling without power to the motor.
Direct drive (DD) hub motors are simpler, quieter, often cheaper, and can "scale" to higher voltage/power without risk of damage. They can be used with regenerative braking, which is good for braking, but not so great at extending battery range (~ 5%ish).
A hub motor can go on the front wheel or on the back. The front is a little simpler, but the back is safer, especially for high power. A torque arm (or two) is a good addition for helping ensure that the axle does not spin out (recommended on the front wheel for sure, preferred even on the back, especially if using high power).
Not all motors can take disk brakes. Those that do have limited clearance so not all disk brakes will fit.
Popular geared choices: eZee, MAC, BMC, ...
Popular DDs right now: Nine Continent (9C), typically the "2807" winding (ebikes.ca nomenclature); Crystalyte, others
A very useful reference is the hub motor simulator on ebikes.ca (http://ebikes.ca/simulator/). It shows the motor power output, torque, and efficiency as a function of speed for different choices of motor, battery, and controller parameter combinations.
3. Controller
The controller is the brain that receives the throttle control and brake signal (to cut power or use regeneration when braking) and decides what power to pull from the battery and send to the motor.
Controllers are sensored (more common) or sensorless; some can do both. Hall sensors "know" the position of the motor rotation and help the controller know how to power the motor for smooth acceleration.
The infineon type is probably the controller type of choice now on E-S (lots of threads here on how to adapt etc). The ones sold by Lyen are valued among the high speed crowd.
Typical controllers handle at least 36V and 15A. More common here would be to handle up to at least 48V nominal and minimum of 20A, even 25A. Really high power ones will handle up to 72V or more, 35A or more.
4. Batteries
Key concepts in batteries are voltage (V), capacity (amp-hour, or Ah), current (amps, A), discharge rate and charge rate.
Higher V = higher top-end speed.
Higher A = more low-end power (hill climbing).
Power in watts (W) = V * A
Higher capacity = more distance, but also more cost and weight.
Calculate the battery pack capacity you need by
Capacity (in Ah) = km * (Wh/km) / V * 1.25,
where:
  • km is max distance in km before recharge,
  • (Wh/km) is 10-20 (10 if you pedal, travel mostly on flats, etc; 20 if minimal pedalling, hills, faster speeds, headwinds),
  • V is your pack voltage (typically 36 V or 48 V, but whatever you choose),
  • the factor 1.25 is to leave 20% unused before recharging, otherwise battery life is reduced. Add another 20% if you plan to keep batteries for a long time, because capacity will decline with battery age.
Charge/discharge rate is expressed in "C", the battery capacity. A rate of 1C is the full battery in one hour. For example, a 10 Ah battery discharged at 10 A would be a 1C discharge, at 20A is 2C discharge (and would last only 0.5 hour).
Lead-acid batteries are old school. Don't go there unless low up-front cost is absolutely key.
LiFePo4 or LiPo are the main choices now. Another possibility is to get batteries from old tool packs etc. sold by some members on E-S.
LiFePo4 is more expensive up front, heavier, no fire risk, theoretically longer life (1000s of charges). pingbattery is one of the best values, but they need a lower C of 1-2C average or battery life is considerably shortened compared with other LiFePo4 choices. So ping batteries (or others with similar C rate) need a higher total capacity to keep the C-rate low enough. E.g. with a 25A controller, get at least 15 Ah.
LiPo is (recently) the cheapest, lightest choice, but needs careful charging or is extreme fire risk (read the Golden Rule and buy LP-Guard or similar fire-containing bags). HobbyKing is the popular source for LiPo right now. Newer quality LiPo can handle >>5C discharge and >2C charge rates; the former means you buy only the capacity you need, the latter means quicker recharges are possible. With LiPo you usually will have to buy several packs and parallel them together for higher Ah (e.g. 2x(5 Ah)), then series connect for higher voltage (e.g. 2 "5S" subpacks for 37 V nominal).
Both LiPo and LiFePo4 packs are sold with terms like "6S2P", which refers to the number of individual cells in series (S) and in parallel (P) within the pack. LiPo cells are nominal 3.7 V each; LiFePo4 cells are nominal 3.2 V each.
Batteries need chargers -- LiFePo4 usually comes with a charger. If LiPo, you should buy a good charger. (Experts sometimes bulk charge directly with a power supply, but "dummies" need one made for LiPo). Popular chargers now seem to be the iCharger 208B+ or 1010B+, or others in the iCharger line. But they (like many chargers) require a separate power supply. Have a look at E-S threads for details, there's too much to explain in a quick guide.
Batteries charge to a fair bit higher than their nominal voltage, and voltage declines as they are discharged. They can be damaged if charged too high, or discharged too low, so they need HVC (high-voltage cutoff) and LVC (low-voltage cutoff) protection. Packs are happier if they are "balanced", i.e. all the cells are have very nearly the same voltage, especially if paralleling subpacks together. Some packs come with a BMS (Battery Management System) computer board built-in to control charging/balancing and protect the batteries from high or low voltage (this is typical with LiFePo4 packs). There are also third-party BMS boards that are sold by E-S members. For LiPo, the charge control/balancing is done by the separate charger, and LVC may be provided during use if desired by add-on monitors (e.g. Battery Medic, Chargery BM6, etc).
Many people also monitor their power use through a small computerized device such as the Cycle Analyst ("CA" everywhere on E-S) or the Watts-up meter. The Cycle Analyst can also measure and limit speed and power use, which can assist in meeting legal requirements.
5. The rider
Your needs/wants likely fall roughly into one of the following categories:
(a) assist power (for higher average speed, help climbing hills) in addition to normal biking with you pedalling
(b) basic medium power, legal (N. America) or not much over (pedalling not necessary, decent speed even up hills)
(c) crazy power, high speed
(a) Assist Power
For assist power, your motor should be minimum 350W (up to 500 nominal), geared (freewheels, so no drag when not using power) or DD okay. Front wheel (+torque arm, always) or back okay. Controller and batteries rated for 36V, at least 15-20A.
In some countries, lower powers are needed to be legal, can be as low as 250W, 24V, 10-14A. More commonly, use at least 36V and 20A, which will get approximately 20 mph (32 km/hr) on level ground. Go to 48V and 25A to maintain 32 km/hr on small hills and headwinds, or to get better speeds up steep hills.
(b) Medium Power
For medium power, you likely want a DD hub motor, nominal 500W or more. A geared motor is okay if at the lower power end. Front hub is okay, but the back hub motor is preferred if going to higher power. Controllers and batteries rated for minimum 36V, probably 48V, 25A.
(c) High Power
For really high power, almost certainly use a DD motor, almost certainly on the back, probably a Lyen controller. Voltages >> 48V, currents >= 30A. Don't go straight to (c), start with (a) or (b) unless you really know what you are doing.
Costs
Full cost to convert a bike is likely to be $500-$1400.
Lower-end kits (not including battery) cost ~$200-$300 shipped. Nicer/higher power kits are about $450-$1000.
Batteries will be $250 to >$500. Example: HobbyKing LiPo, 36V 10Ah, on sale can be ~$200 shipped, but a good charger will be ~$80-$120 and a good power supply for it ~$40-$80. LiFePo4 from Ping, 36V 15Ah is ~$450 shipped, with a 2A charger included. But these numbers are changing fast.
Whew...
Bottom line is this can only be a guide. Your needs/wants for speed, distance, type of bike, etc. will dictate a lot more details. The group here is great at answering questions.
Edits:
2010-12-19 Added HVC, BMS, balancing, "6S2P" etc.; mentioned CycleAnalyst, Watts-up, ebikes.ca simulator; formatted a bit for easier reading
Ziggurat said:
As a newbie myself, who has been reading and keeping notes for a couple of months and think (_think_) I am beginning to understand things, I'll share my notes, as somewhat of a "dummy" guide. This is a basic outline, not from experience (my components are ordered/being shipped), but just my summary of what I think I hear as the majority opinion here. But as others said, things change fast. YMMV, literally..........
Now thats an awesome summary!
Thank you so much, this must have taken a lot of thought (and in my case) a lot of backspacing :)
--T
I would step back even further.
There are three broad classes: readymade, DIY kits and experimental.
  • Readymade range from $500 - $10,000 USD (beyond that is absurd/custom).
    Kits can offer value, but require simple mechanical and electrical skills.
    Experimental bikes range from free to expensive and may pose risk of damage to people and property.
All the above require assessing the application: health, recreation, commuting, service, sport, etc.; also assessment of resources: funds, skills, locations/topography, charge-points, local laws, support-services, etc.
Ziggurat's post is damn good. We should sticky it or make it it's own thread.
Thanks for the kind words on the "dummies" post :). I do hope newbies come across it and find it useful.
I've edited a bit for clarity, and added some more info around batteries and charging/balancing and a few other things (see "Edits" at bottom of original post for specifics).
If anyone can think of other key concepts that are missing, let me know and I'll add them in.
