Sonny Boy said:I ran 2 X 4s 2850 mah 45C that I used on my RC heli.
I did not notice anything unusual and esc/motor were fine.
The speed/torque was way better than stock.
My guess is with a 9s setup, it'll be fine.
I ordered 3 X 3s 5000 mah 20C.
Why so careful. Rarely if ever have heard of them burning while in storage especially as youre balance charging.Sonny Boy said:If you're gonna use Hobby King lipo packs, it's better to have them removable and balance charged .
Like the 3 X 3s I'm getting will be used in series but balance charged in parallel and stored carefully when not in use.
Sonny Boy said:I've got 3 X 6s 3300 mah sitting there.
Trying to convince my geek friend to turn them into bunch of 3s so I can combine into series and parallel.
Not sure he'll do it..![]()
tomtnt said:Sonny Boy said:If you're gonna use Hobby King lipo packs, it's better to have them removable and balance charged .
no offense, but I'd rather put the batteries in an enclosure and remove and charge than stick it ghetto style on top of the board.
I've tested 8, 9, and 10s... i think i will probably stick with 2 4s/8000mah - just need to find a good battery enclosure
jakeyb2525 said:tomtnt said:Sonny Boy said:If you're gonna use Hobby King lipo packs, it's better to have them removable and balance charged .
What did you think of 9-10s ?
Why are you sticking with 8s ?
Ive was looking long and hard for enclosures to keep it clean looking ...best ive found so far is http://www.aliendrivesystems.com/store/c7/Battery_and_ESC_Enclosures.html
the carbon on carbon looks good
Ive bought the 2 x 5s 8000ah Hobby King Enclosure and it doesn't look bad at all...ill post some pics soon
jakeyb2525 said:tung256 said:jake, all you did was pop the 10s battery pack in? did the e-go bms charge it as normal?
how would a sensored motor work better with 10s? and which 10s did you install? any tips is greatly appreciated
The E-go motor is already sesnsored....i just want a better sensorded motor that is definitely rated for 10s
Just unbolt the 6 Hex screws on top of the board and remove the battery pack
if you look at my picture two pages back on the thread... you can see i used 2 x 5s lipos in series to make 10s and connected them to the E-go ESC
i just taped them under the board to test it, but i have bought the 2 x 5s zippy 8000ah carbon enclosure from AD to fit when i get it back from bruno
as for charging.. i have to use my RC charger as i use lipo...if you want BMS and the same sort of low profile battery i would suggest a space cell from Enertion or Alien Power systems, but i think you will still require one of their chargers...but don't quote me on that!
I personally think the motor would definitely last on 10s for most people, im a big guy and live in a very hilly area so i know i will kill it eventually as it was getting quite warm...Im Really looking forward to see what he can do with it as it rides so nice on 10s![]()
If you do try it i definitely don't think you will ever want to run it on the standard pack again...mine hasn't been used since!
Obviously at your own risk![]()
Hmirich said:jakeyb2525 said:tung256 said:jake, all you did was pop the 10s battery pack in? did the e-go bms charge it as normal?
Thank you Jakeyb2525, do u think the space cell will do the job? Is it a 10s? Can u show me how to connect it please? Did you get any update from Bruno about the motor?
Thanks
jakeyb2525 said:The only problem was the motor getting a little hotter than it should... i've sent all my running gear to Bruno to see if he can fit me a sensored motor that can handle 10s better... i don't think the standard motor will last long running 10s
I will let you all know the outcome
