Kepler
Much better. Looks like the ratios are tighter too which I think is good thing.
That would be tricky on a Fighter - there are no ISCG tabs and the Schlumpf BB needs to have a taper. Won't it interfere with the main frame anyway?Kepler said:My next job will be to fit a chain guide to make sure the chain no longer comes off
full-throttle said:What do you think of those cell PCBs? :wink:
jonescg said:full-throttle said:What do you think of those cell PCBs? :wink:
Very effective and super-versatile
Hey how's your 20C pack coming together? I'm still surprised at how small they are.
And also eliminates alot of wiring
Good to know 8)Rodney64 said:jonescg said:full-throttle said:What do you think of those cell PCBs? :wink:
jonescg said:Looks like a bought one I'm glad you drilled that hole and not me The paint job was too nice.
Managed to get hold of a hole saw which was sharp.
korpin said:hey rodney! noticed two front sprockets...you gonna have a way of switching between the two?
Korpin, I have decided to fit a front derailleur, I'm looking for a frame mounted one. Will need to make a modified bracket to fit though. The current chain line will need to move 7mms to the right. At the moment the chains only staying on the small sprocket. I have discussed it with a guy from work and we have a plan.
ohzee said:Looks like you did a great job on the hole. I was wondering myself what it would take to put a CA in there.
Would love to see someone go first though. Sweet looking ride bud I am jealous.
thanks Ohzee, yes it would be nice but it would need to go longways.
jonescg said:Glad you could get it to turn a wheel mate. I'd say that Lyen controller isn't talking to the motor. At least it fits in there.
I hope you managed to get some foam down the sides of the battery pack.
Also, get yourself a velcro strap to hold the highest battery down firmly. You can wrap it around the frame for now, just as long as the cells can't jiggle around.Yes managed to get foam down one side, will start looking for thinner foam. Conveyor belt skirting maybe an option.
What kind of currents are you pulling from the battery? Anything getting hot? Is the cycle analyst saying the right things?I was thinking if I drilled a couple of holes for cable ties to go over the top of the battery, I will first try using the cover holes.
Max amps show 50 but I think I did a full reset. Yes went for a 6km ride and things got hot, controller warm to hot and the motor was hot but still touchable. That was we one 80km an hour burst. Current gearing i can pedal at 40. At least our 100 amp fuse survived.
jonescg said:at the start of each sentence followed by a
