Kike Ming said:So I love all Ebikes, but Phasors are the best! I put some video ( very shaky and bad on Youtube under) fastest electric bicycle in the world , Super fast or find my channel under Kike Ming. Phasor frame 120v battery, 126.9 volts hot off the charger, 24 fet Lyen controller, 10,000w Cromotor. 67 MPH topspeed
Frick, yah, ride or Eletric or die!
korpin said:new HPC 100v controller they say is has Lyen board tried bike at 108 volts and 20 amps got 35 mph will try 30 amps tomorrow got crazy regen on this bike too!
notice they got clear jacket over button to prevent water going in switch
WELL CHARGED it up full to 118 volts.....the controller might have a high voltage cut off the bike will not run now shit was starting to enjoy the regen![]()
does anybody know if Lyen has a high voltage cutoff and can it be re programmed?
dpearce said:Someone asked me how many could be fit in the frame so I figured this information would be helpful here.
20mm diameter batteries representing 18650's shown in a hexagonal closest packed lattice. The internal width of the frame is almost 100mm, so laid sideways as shown you would have more space widthwise, about another 35% where you could theoretically add more batteries in a vertical layer, perpendicular to these and still have room for insulation. There is also the cavities near the headtube and seat tube, where the frame narrows, but several more can be added in there as well before the width of the battery is greater than the width of the frame as it tapers.
Considering those things, and how the cylinders are modeled 10% larger in diameter than 18650's, this picture shows a very conservative estimate of how many 18650's you can fit in a Phasor frame, and configuration shows 366 batteries, or about a third more battery capacity than a Stealth filled with 280 18650's.
Rix said:Korpin, with all of the issue you had with your high volt set up, why didn't you go with a 20s and a vented 4080? You could run 20s at 50 amps through a vented 4080 and have way more reliablity and similiar performance to the 28s and 4065 you are running and having issue with even at 30 amps.
It will lift the front wheel if your not careful and accelerates at a rate I am struggling to comprehend compared to before
9lives said:Rix, yes running a 20S setup which combined with the bikes relatively modest weight (36Kg ready to ride) makes it fun. I ride ICE bikes so performance is by no means scary (won't throw you off from a standstill) but at around 15km/h the torque comes on strong and you can use throttle to lift the front wheel for obstacles etc. From a standstill it will now power up gradients that would have previously stalled the motor. The other positive I have noticed is that regenerating braking works straight away so there is no waiting for the battery to run down as was the case with the 18FET.
Have discovered a negative however. With great power comes.......
4Km into the 9Km bush loop the rear tube let go. Sure was fun walking out of here.
Rodney64 said:Ill take one Allex as well as a max-e for my Phasor.
