Entertain something for me, measure the thickness, should Mic out around 2.5mm to 2.8mm depending on powdercoat thickness.CJonaBttlrckt said:Hi all,
I'm jealous, nice view Rix!
Replacement bomber seat subframe turned up yesterday and the steel plate is somewhat thicker that my original.
Cheers,
Clinton
Thanks Simone, this area reminds me of the lake outside of Nuero Sardegna.bigbore said:Beautiful pic Rix! Bravo![]()
Glad you got it sorted. It was only a guess about the controller I may have been totally wrong but perhaps worth a look.SUNDRIVE said:Re Domino throttle on stock Fighter.
Thanks guys, I sorted it out by pulling apart the throttle body and replaced the micro switch with a NO wired unit. My soldering skills are rubbish so I cooked the first one, lucky I bought two.
Yes Ian it is a Crystalyte controller, stock Fighter, that is good to know about changing the pins, in retrospect that would have been the easiest fix.
Took the bike for a quick test late last night just around the house, it goes; regen- dead spot- throttle action. The dead spot next to regen at fully closed is useful, but a little too wide. I can try rotating the pot wheel gear one tooth before meshing with the throttle gear teeth. Resistance goes from 5.4 kOhm to about 1.9 Ohm. If I adjust the gear position it will likely be 4.9 kOhm to 1.4 Ohm.
Throttle action itself is very smooth and progressive through rpm range. Full width much more comfortable than halfie.
Allex said:Yup, got mine today! Very nice quality(Made in Italy!) compared to traditional chinese throttles
Will be interesting to see how it feels on my new bike.
Archer said:Geez Guys,look at Allex's hand.No oil stained skin.No gunk under the finger nails. See this is what happens when you go from gasoline engine powered bikes to electric bikes!
Tim.
DasDouble said:What tires does a Stealth bike has? 17" motorcycle or 19" motorcycle ones??
Which do you prefer and why?
-Thanks, Cheers, Elias
Rix said:Yah, Dasdouble, check out this thread, there are guys on here that have ran the Bomber with stock 24MTB, 17MC, 18MC and 19MC, I'm guessing you can find the answer to your question here. https://endless-sphere.com/forums/viewtopic.php?f=2&t=55458&start=175
DasDouble said:Rix said:Yah, Dasdouble, check out this thread, there are guys on here that have ran the Bomber with stock 24MTB, 17MC, 18MC and 19MC, I'm guessing you can find the answer to your question here. https://endless-sphere.com/forums/viewtopic.php?f=2&t=55458&start=175
Cheers dude, thank you really much![]()
Rix said:You bet amigo. I am wondering if you are considering a motor wheel for your machine?
Rix said:Entertain something for me, measure the thickness, should Mic out around 2.5mm to 2.8mm depending on powdercoat thickness.CJonaBttlrckt said:Hi all,
Cheers,
Clinton
