Rix
100 TW
Stealth_Rider said:Rix,
Mine was a one cable failure where the cable broke inside the gear selector cap down at the V-Boxx.![]()
Shifter may have felt just a bit harder to turn before failure but, other than that, no warning. When it happens you almost immediately loose all you gears and, if you are lucky to stay in a gear, it quickly loses the gear and seems to end up with a position between gears. Can't do anything except power home.
When I examined the cable that broke I found several strands of the wire rope cable were frayed and broken. Looks like the remaining strand(s) just couldn't handle the twist force and failed.
Possible test for you would be to try to hold the pedals in a position to prevent a gear change and then twist twist the shifter harder than normal and see if it breaks. Before doing this loosen the pawl adjusting screw so the twist test loads the shift cables and what you feel with your hand isn't just the pawl moving out of the detent.
Jim
I think I will put the Vboxx in first gear and pop the shifter cover off and inspect it on the next service. Bike shifts fine, no hard twisting required, and I have squirted some Sythetic grease into the pawl hole and then inserted the pawl, spring and screw. With grease in there, my gear selections are very smooth and very precise.
