Athaneco
Hello
I have a question for anyone that has stripped successfully a b52. I have a 2015 b52 that i want the frame to be repainted due to damage. I m in the process of taking it apart so i would like to ask in order to avoid any damage. Below are my questions for which i would appreciate your replies:
a. How to i safely(without damaging) remove the cycle analyst from the frame (please check the photo)
b. How to i remove the spring from dmm rear shock (the spring only)
c. Is removing the front fork(888) straight forward as it looks or is there any trick i should be careful of.
d. Do i remove the the gear shifting cables , from the hand shifter to pass them through the frame? or do i remove them from the gearbox?. Is there something i should be careful of ?
Many thanks
Many thanks
