Project bike from e-scooter and vanmoof parts
Itzigerstee
Luxembourg
Hi, I’m new to the forum and total noob when it comes to building electric bikes, so I hope you’ll bear with me. I’ve been reading a lot online and trying to learn, and as a first project I wanted to go with using parts I already had.
I’m trying to use the battery, controller, display and other parts from an old electric scooter, with the motor of an old Vanmoof bike and I have an interesting problem. It kinda works, but to activate the throttle, I have to first spin the wheel backwards for a moment.
The electric scooter I’m using as a donor was a Revoe Revolt R.
  • 36V rear motor on an 8-inch wheel
  • Brainpower motor controller (36V, 250W)
  • Battery: 36V, 7,5Ah/270Wh
  • Display unit: S886
The bike I’m mounting this on is an old Vanmoof electrified S from 2017. I’m only using its frame and motor, for now.
  • 36V, 250W front hub motor
As a first test, I connected everything (the connector of the Vanmoof motor is the same as the connector on the scooter’s motor), but the motor activated only when I first gave the front wheel a little push backwards. Once the throttle was activated, the wheel spun forwards.
Normally, with the e-scooter, you would push it forwards to activate the electric throttle. I’m guessing it could be some pinout issue.
Possible ideas/solutions:
- The connector for the motor is symmetric and I wonder if flipping it could work (or would it damage the motor). It's a round 9-pin connector, with 8 pins in a circle and one in the middle. It has a black arrow on the side, showing the correct way to connect it (matching the arrow on the male cable connector).
- Through the P-settings of the e-scooter, I could try to disable the "push to activate" function.
If the scooter required you to push it forwards, it's going to require that for any system you use it on. It's probably a safety feature to prevent runaway operation. If it's a feature you can turn off, then doing so would allow you to start without that.
If you have to move the wheel backwards, its' probably a geared hubmotor, and so it only engages the motor from outside by moving the wheel backwards, but the motor only moves the wheel forwards and can't move it backwards (internal freewheeling clutch).
Otherwise, if you want to start without pedalling forward (or pushing the bike backwards) first, you'll probably have to buy a controller that works the way you want and has all the features you want, at the right battery voltage, that comes with the screen you want (your screen/controller probably only work with each other), at the right current to run your motor the way you want but no higher than what your battery is capable of (so probably no higher than the 7A or so your BP controller limits to), so you don't damage your battery.
Aside from that, to be sure things work correclty you'd need to know (test, trace out, etc) what the actual wiring is of the connectors for the controller and motor. Just because they are the same type doesn't mean the wires are the same, and it is possible to damage parts, especially hall sensors. Even if nothing is damaged, the phase/hall wiring pattern / combination may be wrong for your motor / controller combination, and you may have to experiment with the 36 possible combinations of phases and hall signals to find one of the three forward / three reverse combinations there are.
Without working hall sensors, most controllers that *can* run sensorless (fallback to that when they fail) don't always start from a stop without the motor already moving a little bit.
I wanted to share a small update on this project and some information I found out about the Vanmoof electrified S1 (2017).
Today I connected the electric scooter's battery, controller and throttle/display to the motor of the bike. I found the settings of the display online (manual of the S886) and this allowed me to disable the push function of the e-scooter via the P settings. However, this introduced another problem - the motor started turning even when the throttle ring (of the type that you need to twist) wasn't turned. It only stopped when the brake was pressed and the brake sensor activated.
Initially I thought the reason was that the bike motor wiring was different from the e-scooter wiring, despite both using Bafang motors and 9-pin HiGo Z910 connectors; but then I noticed that there was a point while twisting the throttle, when the motor actually didn't get power. The throttle was broken and the "zero power" position was not where it was supposed to be! I ordered a new throttle to further test this.
To be confirmed conclusion 1: the Vanmoof electrified S's motor, a front hub Bafang G313.250.D 11, is compatible with the controller and battery of the Revoe Revolt R.
the motor
the controller of the e-scooter - it looks quite generic
Encouraged by this, I decided to do another test - would Vanmoof's controller and smart cartridge work with the battery of the e-scooter? Normally, it shouldn't work, at least that's what I read - that everything on the Vanmoof was proprietary, that the battery had a temperature sensor and unless it's connected, the bike would show an error... But when I connected the battery to the controller/smart cartridge, it powered on, the app was able to connect to the smart cartridge and reported the battery percentage!
To be confirmed conclusion 2: the Vanmoof electrified S can work with another battery with the same voltage (specifically the one from the Revoe Revolt R). A remaining doubt is how it will behave while actually riding. The e-scooter battery is of smaller capacity.
Another thing to note is that If all works out well, I'm planning to use the scooter's charger, so I won't use the charging cable of Vanmoof's controller. I hope this won't result in issues.
Small discovery: of the two wires that connect to the battery from Vanmoof's controller, the yellow is the power and the blue is the ground. I couldn't find this information online.
Blue is ground and yellow is power
Now it's time to take the bike for a spin and see if any errors will show up.
the motor
Hello, just stumbled upon your weite up looking for repair ideas for dead S1 I just recently acquired. I really appreciate the insight and findings you provided. Hoping to hear more about your tests ( new throttle control for the Revoe Revolt, powering the Vanmoof with the scooter battery etc.) so that I may revive my Vanmoof!
