litespeed said:Not sure why anyone would do a MXUS when the QS 205 motor is so amazing! It weighs more but you can make it weightless with 12, 15, 17 or 20KW. I have the 3.5T in a 17 inch rim and run the crap out of it peaking at 17,000 watts and still haven’t baked it yet. This is with ferrofluid and Hubsinks though! Definitely runs cooler with the Nucular 24F! With the MaxE I was running and the Nucular 24F I’m running now I can place the front tire against a wall and with the back tire on rough concrete I can smoke the tire….who needs more power than that? Who would want less I wonder? I could still turn the controller up to 20KW if I wanted to but I still find 17KW scary in many circumstances.
Just a different view from a guy who ran a MXUS in the past.
Skip the toys and get a real motor if it’s lacking power or heat resistance.
Tom
Theodore Voltaire said:Yeah, I hear you Tom. I was just thinking the same thing. The QS 205 makes a lot of sense. I didn't think it came with the right drop out width, but I guess it does if Bombers are 150mm.
https://www.amazon.com/Highest-Torque-Electric-windings-Magnet/dp/B086GP9VZV/ref=cm_cr_arp_d_pl_foot_top?ie=UTF8&th=1
1abv said:Clyte 5304 - 4k? 33 lbs
1abv said:So im guessing that the 3000 will have more torque but may get hotter quicker which could be about the same as far as heat control that I have now. But If I want to run 8K peak around 4k constant can this motor handle that? I noticed that the phase wire gauge is thinner than the Clyte and can not physically fit 10awg wire Is that an issue?
thanks!
Alex
Trails are for wusses
1abv said:I got all that from the ever accurate internets..
The cyltes website:
"- 5403 motor phase wire : dia. 4mm 2 x 3 pcs
- Weight : 15kg / ea bare motor"
but who knows...
I haven't weighed mine but with the complete wheel and tire its gotta be at least 45lbs.
Chalo said:1abv said:Clyte 5304 - 4k? 33 lbs
That can't be right. My front X5305 weighs 22-1/4 lbs before lacing it to anything.
cheeko said:Guys
Thought this is cool Australian Army will introduce Stealth ebikes https://youtu.be/_-L5NywFoX4
Now Stealth will have cash to go to next level great Australian company
