Allex said:Jimroy, mxus motor is more efficient,
Here is a graph showing a rid WOT, goin up a 10% hill.
5403 has 78% efficiency and will overheat in 20 minutes.
Mxus has 86% efficiency at same setup and will never overheat at this grade.
stevebills said:I managed to repair a punture on my stealth bomber back wheel without removing the back wheel
and i was wondering if i ever need to remove the back wheel to fit a new tube what is the procedure?
does the wire to motor need disconnecting?
what is the full procedure pls as i am a 6 week old bomber novice?
thx
steve
thx
steve
I know it's a re-post, but check this video for some mounting idea's.Rix said:Thanks for the comments guys. CD, you are the second person now that told me to expirement with different mounting positions while riding, will look into it.
Rix said:Here is my latest vid.
Jimboyr6 said:stevebills said:I managed to repair a punture on my stealth bomber back wheel without removing the back wheel
thx
steve
Im sure iv answer this one already, check back a page or so steve
stevebills said:the punture went down last night and i can get a 26 inch x 3 inch tube locally
will this be okay for a stealth bomber if im carefull fitting it as i no they are 24 inch tires
thx
steve
Theodore Voltaire said:stevebills said:the punture went down last night and i can get a 26 inch x 3 inch tube locally
thx
steve
That's not really a good idea Steve, because the tube will end up with folds in it. For any old bicycle you could get away with it for a while, but on a bike this fast you don't want to take a chance like that.
Emmett's suggestion is a good one. Try finding a 19 x 3 motorcycle tube.
Hyena said:Ouch Rix. Might be time to invest in some downhill shin guards. Should be a bit lighter than MX ones and not get in the way of pedalling but equally effective against nasties like that. I bought some a while back but rarely wear them. It's a trade off, going for a ride when you're decked out like a storm trooper does tend to detract from the experience, especially with some of the soaring temperatures you get there.
