Pinotman said:Hi Guys.... not meaning to hijack the forum on this one... but appreciate some help from your experience..
So the attached pic shows that I 'cooked' my Stealth Fighter (#81) with its original Crystalyte motor today. I need some advice.
I am running a 18650 72 volt+ battery Kelly KLS7218 controller setup with amps set at around 55amps. This setup had some nice pull BTW 10-40Mph and would top out at around 50Ph... I obviously need a new motor now that can cope with the increased amps and Volts from the stock set up.
I am running original Fighter MTB rims and Duro 24x3 type tyres. I ride predominantly off road on steep and rocky hard terrain. I ride this bike and all my bikes very hard..... WOT is normal for me... and i ride the Fighters i have... like Moto bikes when i can..![]()
My two questions are:
1. Its been suggested to me professionally by my local Ebike motor expert that I simply purchase a QS205 and lace that into my existing MTB rim. Now i know that motor is very solid and I think very heavy ( too heavy) as an option and while im sure it will handle the heat that my 72V+ system puts out I think the weight is heaps more than the original Fighter motor ( maybe double?) and I'm not sure it would be good for the unsprung mass on the back wheel of the bike for the off road riding that i do... im also not sure that lacing that motor into the original MTB type rim rather than a Moto type rim would last or be that smart? I'm already around 6.2 foot and 95kgs in weight. Is this bad advice I'm getting to consider this... or I'm being paranoid here? im sure the QS205 has benefits but better suited on road im sure..
2. If you guys had my setup on this early model Fighter and the option to fit best motor ( with an open cheque book) for best low torque and high power off road riding.. what MOTOR would you choose/advise? I want to ride at max 45mph top speed (occasionally as but low down torque and maneuverability off road is more important than top end to me...
I have read a lot of this forum and all the Stealth Owners posts and attempted to disseminate the info .. .. but for for newbie like me on E-bikes with a predominant Moto background i would really appreciate your thoughts/advice here.. im not sure a QS 205 is the best option... I know some of you have stuck with Stealth Factory option.. others have gone sideways.... im sure other options like a more recent Crystalyte, Leaf, MXUS, or even Mac geared motors may work better.. what can you suggest in your experience?
thanks Nic.
Theodore Voltaire said:
Rix said:Theodore Voltaire said:
I have it all wrong, the streamers are what get the chicks, its got to be the streamers.
Pinotman said:Rix, thanks for the heads up here. I have contacted Stealth to ask if they will indeed sell me a H4080 with 162mm Front axle drop outs. I see that i can get hold of Crown TC80 motor with the right 162mm axle but the H4080 will do a better job you think?
Cheers Nic
thanks Nic.
Pinotman said:Rix, thanks for advice. i spoke with Stealth today as they didn't have any H80 series in stock to sell me and only H65's, i bought the new Bomber UFO motor which they will lace straight into a wheel for me and sell me the new harness for the controller needed with this motor so should be plug and play. I'm excited about this new motor ( although its 2 k'gs heavier than the new H80 motor- so it weighs 10kgs) I think it should mean with running Ferro Fluid and Hub Sinks ( that i do run) - im no chance to smoke this one. I guess my lowly 55Amps can come up a bit and the bikes low down torque off road and the moderate top end speed i want ( say 85kph) should both be achievable i hope with this motor.. ( rather than having to pick a wind speed with the H motors) does anyone else you know have one of these UFO motors running in a fighter? I'd like to know if they do?? . Im running a Kelly controller that will run up to 220Amps i believe , but im not heading anywhere near than high just yet... may try around 75 Amps to start and see how the bike feels.
Nicely done, so looking at the kit, it appears to be a separate function fork (SSF) set up. Is that the case?1abv said:OHHH BOY.... someone got a new toy......
mmm no frothy fluids for me anymore!!.... were talkin Americano not Cappuccino!!!...... Olympic pool not 1960's ski cabin hot-tub!!!!.. I digress.
Anyway this is the Avalanche kit for the 888 Marzochi.
A Brief History...
I bought the 888's knowing that eventually I was going to get this kit. So I got the CR which is the least expensive 888 because the internals get yanked anyway. When I 1st bought it I wound up sending it back due to a crazy amount stiction which wound up being a manufacturing issue with the lower crown unit covered under warranty. I also added the 6.5 weight (HD) spring to it which allowed me to properly set sag. I have taken the fork apart a few times to change fluid, seals etc. and was not impressed to say the least. Here is a pic from Avalanche website of the stock internals..
I have never been impressed by MTB suspension usually the internals are cheap and wear out quiclky much like an Iphone... but at least this was better than the DNM forks that came with the bike. They handled the square edge high speed stuff better than the DNM. but still It was no where near dialed in dirtbike suspension which is where my point of reference is.
In comes Avalanche....
I spoke with Craig for a bit and a few weeks later a box arrived at my door with goodies in it.
So out with the stock guts and in with the avalanche. What this kit does is convert the fork to an open bath setup with high quality custom metal components that are re-buildable and can be easily re-valved. Don't let the open bath throw you off the range is pretty damn epic. Also you can add a "Floating Valving Assisted Threshold/High Speed Blow-off System" that allows a firmer feel while still being plush on high speed square edge trails if you like a firmer feel. He provides a setup chart and if you so choose specs for different shim stacks depending on riding style or preference.
Quick ride report / Result:
When I first assembled the unit and bled the unit before the movement was very smooth. Avalanche includes a specific screwdriver (a small flat head with a dull tip) to adjust the clickers. I double checked where the clickers were at and also wanted to see the difference between full in and out was. The range was very specific and subtle, Craig told me that this was the case when I purchased it. In garage testing just pushing the fork down by hand the fork didn't feel that much different than the stock which initially concerned me and got me to thinking.. what have I done????..what was I thinking???..ARGH!!.. And then I took it out for a ride....
GOOD:
Um yea if you ride offroad this is the set up. I highly doubt that any oem MTB fork is going to match this. It truly brings it into the world of set up moto forks. I was railing down a trail filled with ruts and rocks about the size of my fist or larger and a boat load of worn in holes in the ground that hikers used to create steps. On my stock 888's the front end was harsh and would bounce around and deflect and transfer all that harshness to my arms. With the Avalanche set up I didn't realize how fast I was going until I got to the bottom because I didn't have to think about my suspension. It just worked.
The deflection and nervousness is gone. My wrists and forearms worked less because the forks didn't transfer as much of the harshness of the terrain to the bars. The next day I did a steep downhill that had 2-3 ft ramps built into it and the landings were smooth and easy. Flat hardpack dry turns the forks again stepped up where the stock 888's left off. To sum it up extremely confidence inspiring.
On the stock 888's I played with the clickers and was never happy with how the forks performed. With the Avalanche kit It came out of the box set up for me.
BAD?
-He doesn't tell you that the forks are so damn good that you are now very aware how much of a compromised turd the rear shock is, and that's after I had the shock custom re-valved for me and re sprung for my weight. (Avalanche does make custom shocks don't ya know)
-I wouldn't really call it bad but they aren't cheap but with the price of the forks and the kit its actually a bargain compared to $1,000 diamond or ohlins systems that aren't even set up for your specific riding style.
-good or bad your call....Your dealing with a small company and speaking directly with the guy making the kit. He's pretty specific.
Now the last thing to do is chuck on a set of SKF seals......blammo....
P.P.S im not any rep of Avalanche or getting anything from them.. I just dig the kit! They also make kits for other forks.
1abv said:That is correct. The fork has the damping on the R side and the spring on the L (when sitting on the bike) so only 1 unit is needed. When the kit is installed you remove all of the R side internals and replace everything including the caps and adjusters with the Avalanche unit.
1abv said:Hey fellas what do you think about this battery pack?
72v 24ah
this is EMP out of Las vegas
charging $2000 USD for the pack...
We use the New 21700 cells for this big battery system as most stealth bikes can output up to around 60 amp continues discharge so a strong more powerful cell will help get the best performance form your battery systems.
You must order a charge also if you would like to order this battery as these cells are LI-poly. The chem is different on these battery cells please click this link here to see the charger Click Here
End-off voltage(V): 65
Charging cut-off voltage(V): 84
Rated charging current Amperage of BMS (A): 15
Maximum Instantaneous discharging current Amperage of BMS (A): 160
Maximum continuous discharging current Amperage of BMS(A): 80
Battery Cell: 21700 RPE Cell
5C discharge for RPE Cell
Max charging Current Amperage (A): 15
Cycle Life - 500
Charging Type(CC-CV): CC/CV
Cut-off charging voltage(V): 84
Charge temperature range ssd: 0-50℃
Discharge temperature range: -20–50℃
Dims
13-5/8 inches Length | 346 mm
6 inches Wide | 155 mm
4-3/8 inches Height | 111 mm
tolkaNo said:Lol so many people have snapped the rear shock mount on the fighter and those futr frames.
