Ebike Intelligent Motor Controller YK70F - Wiring diagram?
ebike-ebike
100 µW
I just pulled the controller from my brand new Cemoto folding mountain ebike to possibly add a LED display (has no display) or maybe more PAS levels (has only 1 booster level).
Anyone have a wiring diagram for this controller??
The controller label shows: 'Intelligent Motor Controller' Model# YK70F (LD-NL-S) (LBNL389) and is a 36v 15a brushless controller for a 300w geared sensored motor (8 wire motor connector).
It has PAS sensor (1-booster), 2 brake cut-offs, and throttle connector. There are several other open connectors (white which I believe is speed limiter) yellow & orange.
What is an ''Intelligent Motor Controller' anyway? It is only 2" x 4" x 1" (and doesn't look all that intelligent, lol)
If you took it out from your bike, surely, you can reconnect it and follow the wire to see what they do? "Intelligent" means that it has a microprocesor onbyhe pcb. If you want more PAS levels, you need to replace it. Choose a controller that comes with wiring insttuctions. A S06S if your motor has hall sensors, otherwise a S06P from BMSbattery will probably be a good choice.
Thanks, I was just hoping that the unidentified connectors of the controller could be of some use to me. And still not sure what a intelligent microprocesor pcb is?
I was thinking of upgrading anyway (the hub motor from 'geared' to 'DD') and more 'torque' (higher amp controller and motor, 5-levels of PAS, LCD display).
Basically, the most power (torque) vs speed (20 mph just fine) that I can fit in this in-frame controller & battery space (bike has a foldable frame that houses 36v controller & battery so controller space is limited to approx. 3" x 5.5" x 1.5")
I do actually prefer the controller you suggested (torque simulating from BMS) but still cringe at the $135 shipping fee.
I was thinking about the kits from ebikeling.com on eBay (Illinois, free ship) (36v / 22a Rear hub kit):
http://www.ebay.com/itm/36V-500W-26-Rear-Direct-Drive-Kit-Ebikeling-Electric-Bicycle-Kit-ebike-750W-max-/141702811631?ssPageName=ADME:X:RTQ:US:1123
The problem is that when I emailed them, they could not verify it was a torque simulating or not.
How it works now is that when I pedal, the bike has little torque and wants to go to 20mph and I'm constantly using the brake, so I do want the torque type instead.
The shipping isn't $135 unless you live at the North Pole or some Pacific island. It should be about $35 for a LCD and controller.
Lol,when you add the 26" wheel it goes from $35 to $135 shipping.
(The ebikeling.com kit includes the wheel and free shipping).
Can you please explain to me what an 'intelligent motor controller' is and why it's different than a normal controller?
Thx.
