The APM is showing the wrong voltage and as a result the motor will not move at all
I am stumped as to what the problem is, here is what the APM is showing around 46volts
Here is what my 72 volt pack is showing around 75 volts
I then connected the controller to the battery and probed the controller side to check the voltage, here is what i got.
Strange..... its showing a lower voltage
I assumed a faulty connector on the controller side so I crimped on some fresh Anderson connectors and I'm still getting the same issue can anyone figure out what's happening any help would be appreciated thankyou !!
