Hey pretty new here on the forum but was just looking for some advice on a relatively simple eboard build.
If anyone could recommend any parts that they think will do the job that would be of great help. Ill be riding around relatively hilly ground. That said a low kv motor would do the job better as i've seen, but also advice on the gearing would be very helpful as i'm not to sure on what to go with, in terms of tooth numbers.
http://www.hobbyking.com/hobbyking/store/__18180__Turnigy_Aerodrive_SK3_6364_213kv_Brushless_Outrunner_Motor.html
That is the motor im currently looking at, the kv rating does go lower in this range, i think down to like 160kv.
2 3cell 5000mah lipos purchased from HK.
http://www.hobbywing.com/product_show.asp?id=239
I have seen this esc mentioned around, is it recommended over a hobbyking model such as a trackstar?
For trucks/wheels a pair of Paris trucks with some blank flywheels seems like the way to go. Being based is Australia shipping is the biggest issue with the pricing of everything.
With the motor mount, at the moment the plan is to make one myself and have it welded to the trucks.
Any advice on what i've mentioned or if you could point me in the right direction in terms of other threads that would be greatly appreciated. Thankyou!!
