John in CR
100 TW
After reading a post about 8" or less cable length necessary for a high powered RC motor, I worry about the length of all of my wire runs. What are the specific effects related to cable length of battery cables, phase wires, and hall sensor wires? Obviously resistance turns into heat and limits the maximum available power, but can it affect performance in other ways? Should we twist or braid our hall sensor wires, does cable length affect the controller's communication with the motor, etc?
I ask because when I rewired my hub motor I installed 2m long cables, because I'm treating my current bike as a test setup and don't know where my motor, controller, and batts will eventually reside, and I don't want to have to splice wires later by cutting them short now. The excess currently resides in large loops. I used straight runs of 24ga for my halls, because twisted pairs of cat5 wouldn't fit through the hole in the hub with the 14ga phase wires I settled on. The result is all 8 wires to the motor run parallel for 2m inside plastic tubing all the way to the controller thru a few loops tied in front of the handlebars (please ignore that obvious increase in wind resistance).
On the battery side, with 72v going into an Ecrazy controller powering a non-geared 500W hub I got from Knuckles, I'm running zip cord about a meter long, 2 conductors for positive and 2 for negative. I realize that I should beef that up a bit, but I bring it up because I wonder about the effect of the several loops I have around the seat post along the way.
Do all these cable no-no's add up to a noticeable affect on performance, or should I not worry about it and shorten the cables and run bigger battery leads later?
John
John
