Chrisheuer
ok here is a short saga!! Making a christiana type ebike for me and my disabled daughter. I've changed frames to a worksman front load frame things are going well motor is working Gmac I'm zip tying down cables give it a test and one little pop back by hub and it appears i've stripped the shield the motor harness. after removing the hub and trying the motor again with the cable not bent it runs but as you can see from the pic it is ripped to hell! Ive looked at the grin videos about disassembling the gmac and replacing the harness. nothing looks fun or easy.
Questions
it appears only the small orange cable is severed one of the larger wires is appraised is replacing the cable harness the only fix.
when putting the torque arm on I had trouble getting it in a position where it wasnt slightly pinching the cable with may have lead to this.
Ive been working on this bike for years now, I'm not one to giveup, I'm wondering if the group knows any body in the columbia mo area that works on ebikes ?
Is harness replacement on a gmac a hard task?
Questions
