ProgramThyself
1 W
- Joined
- May 20, 2019
- Messages
- 50
Lebowski explained that stator oriented control (SOC) gives better regen braking efficiency than field oriented control (FOC).
I guess there is a subtle difference between extracting from each amp of phase current the maximum mechanical braking power (FOC) vs. the maximum electrical power (SOC) because motors are lossy.
It's hard to argue with the reasoning, but how much efficiency does this gain?Lebowski said:For me FOC means that (when powering) the motor current vector is lined up with the Back EMF vector, for max efficiency. During regen the current vector is lined up with the Stator voltage vector, again for max efficiency. This is called SOC, Stator Oriented Control.
