Lowell said:
I went for a 43.5km cruise tonight, max speed 81km/h, average speed 44km/h. Did some sightseeing at the beach, fast turns, 1 burn out and a few wheelies. Averaged 35.9Wh/km.
Lets look at these nubers again:
1) 28.4*19.9 = 565 Wh, 28.4/35 =0.8 h, 565/0.8 = 700 W, 35 km/h = 590 m/min, 20''rim = 1.6 m, 590/1.6 = 365 rpm at Kv = 10rpm/V 365 rmp => 36.5 V (working voltage )
lets assume 16 A av. current so 16A * 400 mohm =6.4 V (waste/heating voltage)
So lets check we assume right current: 700/(36.5+6.4) = 16 A so it is right average current for that case.
16A * 6.4 V = 100 W for heating loses
so you have 600 W of working power and eff. = 6/7 = 86%
2) the second case: 43.5*35.9 = 1600 W, 44km/h => 460 rpm => 46 V
lets assume 30A av. current and check them:
1600 / (46+30*.4) =1600/58 =27.6A, so assume 28A now:
1600/ (46+28*.4)=1600/57.2= 28A so it is correct now.
28*11.2 = 313.6 W and average eff. still better than 80%
But you have to keep in mind that real eff. will be lower as your speed varies from av. speed and we skip additional loses at simple calcs above.
Lowell said:
Ideally I'd like a 5304 in a 20" wheel with 132V. That would give the best of everything. 160lbs thrust off the line, great efficiency at just about any speed, and around 91% at 60mph cruise. Lithium power of course... 8)
Try to cruise at 40 mph only at possible constant speed as much as you can keep(at flat road) and check your wh/km.
I'm sure your av. current will raise above 40A and yor eff. drop well below 80%.
So any voltage change can't keep your eff. at 90% level.
