El cheapo freewheel crank setup; bb drive use?
florida
This is just a heads up. I may have posted this before, not in this sub forum though. This is a USED circa $10 shimano FFS setup and also a $15 adapter for my OPC frame. I'm not going to run motor power through it, but you could do. Anybody needing a cheap way to go BB drive might be able to use something like this. Maybe bolt up a #35 or 219 sprocket or whatever.
Chainwheel has a deep lip and needs a little clearancing with the angle grinder if you use an OPC adapter. The FFS stuff was kind of a flop from the 80's. You may be able to find this stuff for free out there.. The ones I have use the standard euro thread pattern, but I have seen some OPC version pics on the web.
