rodgah
got some headstem bearings into it and took a small vid to show the relative size of the frame.
[youtube]JGDf1PRJIFE[/youtube]
Kurt said:Just keep in lookout for cracks forming on that SS frame. It doesn't tend to lend its self well as frame building material. You might get away with it for a while. That's why you don't see to many ss frame bikes around other than the weight.
Kurt
rodgah said:
Cheers
sn0wchyld said:Do you need to reconfig for charging?
I think I might be doing something similar already, only I still use the discharge leads for charging too, rather than through the db25. I still have to reconfig as my charger only manages 8s charging, and im running 20s. Using the spare pins for the main leads is a good idea, but how many amps can the pins take? Im charging at 30-40A, so not sure they'll take that...rodgah said:sn0wchyld said:Do you need to reconfig for charging?
nope....the db25 connector at the bottom has all 12s cells or 14 pins for balancing and the remaining pins share (-) and (+)....5 each. This is not a new technique, I am copying what alot of people have already done, and it is a neat solution to balance charging lipo.
dont worry, i think everyones first attempt looks terrible, mine looked like abortions thats for sure, but the more times you do it, the more you get a feel for how to make it neater and simpler.
cheers
++SamTexas said:Subscribed. I'm amazed at the skill and effort you put into this build. Is this a common trait among downunder's members? More pictures please.
One question: Since you were building from scratch, why didn't you make the battery box part of the frame?
Whiplash said:Absolute work of art, one of the very best builds on the Sphere in my opinion! I love the detail work and the simplicity of the look! You are one hell of a craftsman!
its a hope mono floating disc. Plenty of members on this forum use them....doc007 said:that is a sweet build! it looks like you are running a floating disc brake. when you get a chance can you show some more pics of it?
