I also like the Townies. Lots of room for batteries. I run 18s 3p in the frame and 6s 2p on a rear rack. With their long wheel base, they handle great at high speed.
Super nice KimA, I bet it handles awesome have the batteries so low.
I am also looking into the MXUS DD motor. How do you like the kit so far?
Which motor wind did you get? Did you get the 9 FET or 12 FET controller?
Beautiful. The pedal forward bikes ride so nice. I just personally need to stand the pedals more for any longer rides, due to a bad lower back. But I'd be on something just like that if I was young again.
The bike now has over 100km on is't back, and is still drives perfect. The std. break pads gets worn a bit fast, but that must be the speed and wight of the bike.
Anderson and switch is mounted in the box, so that I can parallel charge the LiPo's. Serial wire harness for controller and parallel wire harness for charging.
The motor wires are wraped with black heat shrink, so it looks like one wire
I've just started building another bike, with a batterybox with the same concept... pictures up soon.
