Electric Chinese Scooter working funny/not working HELP PLS!
PaddyS
🧲 New user
Corrientes, Argentina
I have a Honshu S09 electric scooter.
Im having some issues that when going normally through small potholes or street imperfections, my scooter looses power.
i tried opening it up and i realized that it is in very bad shape inside. The battery seems in bad shape even though it only has 520km and I use it daily since it had 160km
I tried accelerating with the scooter opened and tapping the controller makes it loose power, tapping it again regains it.
i think thats the issue going on, something loose inside the controller.
the other problem i had was related to acceleration, when full throttle in 1st almost all times it shuts off inmediately. i have to graduate the acceleration in order to reach 30km/h
Now it just randomly stays fried in 00 screen with an intermitating RED ! to the side and E-0006. idk whats going on i would really use some good help
PD: nor the battery or the controlled had ANY cushion to absorb vibrations. and it almost broke the controller housing. (those marks on the left are from the screws on the scooter housing)
Based on the issues described, the battery itself probably needs to be replaced (the apparent physical damage to it would be a reason even if it was working normally).
The controller and/or display or the wiring between could be causing the last issue, but you'd have to check it's manual to find out what the error code means.
