bengineering
Hello from Derbyshire, England
A couple years ago I built a small electric go kart for my two young sons to use. It has a single rear 500w hub motor and two front wheels. Its great fun and goes fast on the flat (22mph) even with me on board. As my boys are only 4 and 6yrs old I have fitted a mechanical stop on the thumb throttle to limit speed to around 10mph.
The place where we use the go kart has some hills and the hub motor just hasn’t got the torque to get up some of them, especially as the boys are getting older. So my plan is to use some electric motor I have to build a new ‘hill climbing’ 4 wheeled go kart. The mechanical side of design is sorted (20 years as a mechanical engineer) but I need some assistance from you fine people with the electrical elements
I already have two of these motor kits (450w 36v Unite)
http://www.aliexpress.com/item/MY1018-450W-36V-gear-brush-motor-with-Motor-Controller-and-Twist-Throttle-DIY-Electric-Bicycle-Kit/1808574078.html
The plan is to build a four wheeled go kart with two motors, each driving its own rear wheel.
At max throttle position I want to have a max speed of 10mph and an optional second speed limit of 5mph, so my youngest son can use it safely.
Questions:
What’s the best way to run two identical controllers and motors off one throttle?
The max speed of the gokart can be fixed by matching the drive sprockets to the max rpm of the motor, but how can I electronically limit the throttle so that full throttle position only gives half speed of the motors?
If I want forward & reverse what is the best way to switch the power to the motors? These switches look like they would work for one motor but ideally I’d like to have one switch that controls the forward/reverse of both motors
http://www.aliexpress.com/store/product/30A-0-110V-DC-forward-backward-and-stop-reverse-switch-Electric-tricycle-inverted-switch-severing-controller/1209624_2053846286.html
Thanks in advance for your help !
Questions:
