cmilton45
10 µW
I have electrified my minibike. Hawg Ty Minibike almost identical to Baja Warrior. Thick tires; not a small minibike. This bike comes stock with 60 tooth 420 sprocket. I added:
1. 3000 watt brushless Vevor motor
2. 11 tooth 420 sprocket on motor
3. 420 chain
4. 72 volt 20AH battery (not a cheap one)
Bike goes about 40 - 45mph, but just after 10 minutes of use the motor gets very hot. On 2 separate occasions, I burned out 2 motors only after 10-15 minutes of use. No problems with Battery and no problems with controller. Just two separate motors getting burned out.
? Do you think the chain is too heavy for the motor (working too hard ?
? Do you think I need like an 80T or 85T sprocket on the back to increase torque?
? Or is this motor not meant for such a big bike?
Thank you
3. 420 chain
Thank you
