the flickr link you posted goes to your login/organizer, rather than to a place others can view the pics. if you post your link with your flickr username instead, we can see the pics. like this:
http://flickr.com/photos/amberwolf
so for the battery wiring, you presently have it like this?
mlt34 said:
white controller wire to empty red battery pole closest to the seat
black controller wire to empty black battery pole closest to rear of the trike
to be certain, are you saying that you have never seen the trike move forward at all, even after engaging the clutch levers on the gearbox(es) out of neutral into drive?
i ask because you said previously that all that was wrong before was that the lever(s) were in neutral, which implies that the trike did drive forward when they were engaged.
if it went backwards then, too, then it is likely that the motors were already wired backward to start with.
if it was not tested before, then there's no certain way to know, but it is still possible they were wired backwards already.
if it was tested before and it went forwards, then the motor wiring can't be wrong if it was not changed when teh batteries were removed for storage, and it must then be that the battery wires are not correctly connected now. that would mean that the black wire is actually the positive battery wire, and the white wire is the negative battery wire.
however, if that is incorrect, and the controller is not the simplistic type it appears to be, it will probably damage or destroy it.
for the motor wiring i can't tell you for certain which wires to swap without knowing the whole wiring diagram, and i can't see clearly what wires come from where and go to where.
but a best guess is that if the connectors for each motor are not polarized but each have two prongs, you can simply unplug each one, turn it 180 degrees, and plug it back into the same connector it came out of. but you have to reverse both of them before operating it.
if the connectors are only one prong each or only go to one wire from the controller, then simply unplugging both connectors, and swapping which one they plug into on the controller's wires, will reverse them.
