Peterfr12
View attachment 4View attachment 1Hello everyone,
I am Pierre from UK. This forum is really fantastic, a true gold mine. After spending years reading different topics, I decided to electrify my heavy tourer bike. Indeed I am fed up of my 25 miles commute (north of London in UK) each way by car (cost, environmental issues, wasting my time in traffic jam, subsidising terrorist states, etc.). I myself a keen cyclist – a lycra man - and can reach 30 mph without any problem and sustain such speed for 8 minutes. I used to cycle more than 120 miles in 6 hours. However I don’t have access to shower at work and I cannot realistically ride 50 miles every day and do my job properly. I am only riding on tarmac. I am rather lean 67kg (150 pounds) for 1.82 m (6 feet).
The bike and the kit:
I bought from em3ev a mac 8t kit with a 58V 26.6 Ah battery, a 40A controller and the latest version of the cycle analyst. This 2kW kit has been added on my heavy tourer bike (steel frame and unsuspended fork) with racing drop bar (rather unusual) and bar end shifters. The bike is made by orbit in UK. The brake are Shimano deore XT V brakes with Koolstop brake pads. I have no disk brake and no suspension at all. I swapped my 48 chainring with a 56 one in order to pedal at a lower cadence with an 11 sprocket. I just use only 3 speeds, 56 x 14 to start and then 56 x 13 and 56 x 11. The tyres are Schwalbe marathon plus.
I added the following items as I require more space on the handle bar:
https://www.sjscycles.co.uk/accessories/thorn-accessory-bar-mk1-t-shaped-105-mm-extension-222-mm-0-deg-satin-silver/ to hold the cycle analyst and the switch.
https://www.sjscycles.co.uk/accessories/genetic-neuron-accessory-bar/ to hold the throttle. With this item I can get access to the throttle either with the hands on top of the bar or on the dropped bar.
In order to ride safely during the winter time, I added the following item, a front light 12-85V, 20W motorbike light, http://www.ebay.co.uk/itm/LED-Headlight-Lamp-12V-80V-20W-Universal-Black-for-Motorcycle-E-bike-UK). I plugged directly to the cycle analyst via a female D jack. I think it is too bright as I have been asked by a vulgar pedestrian to use it as an endoscope : ‘stick your f..ing light into your ass’.. I will look for something else.
Statistics after the first 2100 km:
To cover my 25 miles, I used less than 11Ah. The 25 miles were done in one hour. I am always pedalling. With a 56*11 chainring, and clipless pedal, I reached a 38 mph (recorded by traffic radar) on the flat; most of the time I ride at 35 mph. I choose to commute only on road where speed is limited to 20, 30 and 40 mph for safety purpose and where there are a lot of traffic radars so drivers respect the speed limit. With 900 W I can reach 30 mph while pedalling strongly. Riding as fast as the car is the best way to avoid accident because you do not annoy drivers. Therefore the 250W law is stupid. I have to cross several towns and village where I have to slow down. Few cars passed me (less than 5) during my one hour trip and several drivers are looking with the thumb up at the stop . On a 7% gradient, I reached 29 mph. There are 2 long hills of 1 mile (7%) and 2 miles (6%) on my commute. My build is very stealthy with the two Ortlieb paniers hiding the motor; the controller is under the top rack. One panier contains the 7.5 kg battery, the other one my old heavy laptop and its charger, charger for the battery, my clothes and safety shoes for work and my lunch (another 6 kg). The bike with everything included weights more than half my weight 37 kg; I can barely lift it. Unfortunately all the weight is on the back and I bent my wheel after 1700 km while going twice through a pothole at 60 km/h downhill. The V brakes are not good enough when the road is wet. Sometime it is hard to handle the bike at high speed with the high gravity center.
About the kit
This setup is not the most powerful for an ebike but it is awesome. Unfortunately there was no instruction coming with the kit so I have to dig information on this website. The bag designed by em3ev which holds the battery is not good for the weight of this big battery. After only 30 miles several handles were torn and I am only riding my bike on tarmac! It is not a problem now since my battery is now hidden inside a panier.
Questions:
I am riding mostly at full throttle. What should be the maximum temperature I can reach without damaging the mac motor? At the end of my 25 miles trip I reached temperature between 90 110 C. Is it too much? It seems that the output power is limited once I reach 100 C by the cycle analyst.
I purchased the 5A NCM/Li Ion chargers from em3ev with the battery with a 3 position switch. I always charge to 57.4V to lengthen the number of cycle and I charged the battery twice a day (so far 27 cycles). However it took nearly 5h to charge 10Ah so it is not a 5A charger but rather a 2A! Maybe I should inquire along Em3ev.
Future ebike: a recumbent 20-26
I think I need suspension. My back is suffering as well as my neck due to the tuck position. I cannot ride every day my bike (usually 4 days over 5 when I work onsite). I am thinking of purchasing a recumbent bike (26-20 so easy to stop and start in city) like the Nazca Paseo (Dutch steel frame) or the Azub six (Czech aluminium frame) with disk brake. I tried one last month with dual suspensions and I was quite pleased with it. I haven t seen a lot of such setup on endless sphere. I might purchase the Paseo steel frame and build my own bike with maybe moped rims if it fits the frame. i can add the battery under the seat to lower the gravity center. Any other ideas?
Many thanks for reading.
Pierre
About the kit
Questions:
Pierre
